Why is sq rt of -1 needed in wave equations
  • Thread starter Thread starter gaminin gunasekera
    Wave
The square root of -1, represented as an imaginary number, is not strictly necessary for wave equations but simplifies their analysis significantly. Using complex numbers allows for easier mathematical manipulation, particularly in representing sinusoidal oscillations as circular motion in the complex plane. The real oscillation can be viewed as the projection of this complex representation onto the real axis. This approach streamlines calculations and enhances understanding of wave behavior. Overall, the use of complex numbers is a valuable tool in the study of wave equations.
gaminin gunasekera
why is sq rt of -1 needed in wave equations
It's not needed or necessary. However, the introduction of complex numbers into the analysis of wave equations can very substantially reduce the effort required to solve and understand them.
The way I like to think of this is that when you have something oscillating sinusoidally, it's easier to do the math if you think of it as going around in a circle where one of the two dimensions the circle needs is imaginary.
cos(theta) = Re(exp(i*theta)) = Re ( cos(theta) + i*sin(theta) )
The real oscillation is just the projection of the complex oscillation onto the real axis.
Hello! Let's say I have a cavity resonant at 10 GHz with a Q factor of 1000. Given the Lorentzian shape of the cavity, I can also drive the cavity at, say 100 MHz. Of course the response will be very very weak, but non-zero given that the Loretzian shape never really reaches zero. I am trying to understand how are the magnetic and electric field distributions of the field at 100 MHz relative to the ones at 10 GHz? In particular, if inside the cavity I have some structure, such as 2 plates...
