Why Is Substitution Failing in Integrating This Function?
songoku
Find
$$\int \frac{x^3}{\sqrt{16x-x^8}}dx$$
u - substitution
trigonometry substitution
I tried using substitution ##u=\sqrt{16x-x^8}##, didn't work
Tried factorize ##x## from the denominator and then used ##u=\sqrt{16-x^7}##, didn't work
Tried using ##u=x^4## also didn't work
How to approach this question? Thanks
This was the right approach, but your u-sub is too fancy. Use a different u-sub from the expression ##\sqrt{x(16-x^7)}##.
It falls into place after that. In this problem you'll have to bring something back from outside the square root (which you'll see once you use the right U-sub), a complete the square, and a trig sub.
Thank you very much for the help romsofia
##u=\frac{x^{7/2}}{4}## looks promising
