Why is the expectation value of the commutator not zero in method 1?
  • Thread starter Thread starter alizeid
    Qm Value
The discussion revolves around the expectation value of the commutator in quantum mechanics, specifically in the context of polarized photons represented in different bases. The original poster attempts to understand discrepancies in their calculations using two methods to extract the expected value of a |+45> polarized photon in the HV basis.
  • Participants question the origin of a minus sign in the calculations and the nature of the operators involved. There is also a focus on the definition of the |45> state and its relation to the HV basis, with some participants expressing confusion over the expectation value of the commutator being zero.
The discussion is active, with participants providing guidance on the need for clarity regarding the definitions used in the problem. Some participants assert that the expectation value of the commutator should not be zero, while others argue that it must be zero for the given state, indicating a divergence in interpretations.
There is a lack of information regarding the textbook being referenced, which is noted as crucial for understanding the problem. Additionally, the distinction between states and operators is under discussion, which may affect the interpretation of the problem.
alizeid
Poster has been reminded (again!) to use the Template when starting schoolwork threads.
I'm trying to extract the expected value of a |+45> polarized photon in the HV- base. I do it in two ways, one is correct and the other I get wrong answer. What am I doing wrong in the first method that is wrong?
method 1
method 2
thanks in advance
You computed the expectation value of different operators. Where did the minus sign come from in your second method?
Also, please type out your expressions instead of attaching them as images.
why are they different operators? according to the book, they are the same
Then you either copied the book wrong or the book is wrong.
The real problem is
I get the expectation value of the commutator to zero, even for operator | 45>. This can not be correct. I can not solve this problem, can you help me?
The problem formulation is of little use unless you define the ##|45\rangle## basis in terms of the HV one and define what is meant by ##\mathcal P_{HV}##. Since you have not told us what textbook you are using and we most likely will not have direct access to it, this is crucial information.
##|45\rangle## is a state, not an operator.
So what is the problem?
The expectation value of the commutator should NOT be zero. the commutator do not commut therefore the answer is wrong
No it isn’t. In fact, the expectation of the commutator must be zero for the given state! Anything else would violate the uncertainty relation.
