Why is the induced EMF on an inductor equal to -L (di/dt)?
  • Thread starter Thread starter zero_kilo
    Energy Inductor
The discussion revolves around the concept of induced electromotive force (EMF) in inductors, specifically the relationship expressed by the equation E = -L (di/dt). Participants explore the reasoning behind the signs and values used in this equation and its implications in circuit analysis.
  • Participants attempt to understand why the induced EMF is represented as -L (di/dt) and question the reasoning behind using E = +L (di/dt) in certain contexts. There is exploration of the integration process for calculating work done and energy stored in the inductor.
Some participants provide insights into the nature of induced EMF and its opposition to changes in current, while others express confusion about the application of the signs in the equations. Multiple interpretations of the relationship between applied EMF and induced EMF are being explored, indicating a productive discussion without explicit consensus.
Participants are navigating the complexities of circuit behavior involving inductors, including the effects of changing current and the associated work done against induced EMF. There is an emphasis on understanding the implications of the negative sign in the context of energy considerations.
zero_kilo
so the amount of work done to drive the current through the inductor is given by
dw=Eidt where E is the emf of the variable voltage source.We put E=+L (di/dt).
can you please tell me why we put that value?? (i know the induced e.m.f on the inductor is - L (di/dt)
thanks :smile:
while calculating the amount of work done we have to take the integration. For that we have to reduce the expression of dw in single variable
So dw = Eidt = L*i*di/dt*dt = L*i*di.
Now take integrations to get the energy stored in the inductor.
thanks but this is what i actually asked
thanks :smile:
why we put E=+L dI/dt for the applied e.mf:confused:
Consider the equation E = -L di/dt. The minus sign in the equation indicates that the induced EMF has an orientation that opposes the the change in current.
The reason why it's positive for your given equation, is because positive work must be done to induce the current. We need only the magnitude of E then.
thanks :smile: but why to drive the current through the circuit so as to defeat the induced e.m.f -L di/dt we need Ldi/dt; don't we not need a greater value??
thanks again.
The induced emf is Ldi/dt; the negative sign just indicates it opposes the battery's emf. The electrons pushed through the inductor must overcome a voltage of Ldi/dt (that is, they must overcome an increase in potential of magnitude Ldi/dt), so they gain Lidi/dt of potential energy per unit time. This gain in potential is what the energy stored in the inductor really is.
I don't think that this is quite correct.
Consider a circuit with an applied emf, resistor, and inductor, where the current varies with time. If the current is increasing (di/dt > 0 ), then the self-induced emf opposes the direction of the applied emf. If the current is decreasing (di/dt < 0), the self-induced emf is actually oriented in the same direction as the applied emf.
In both cases, the self-induced emf has orientation that always opposes the "change in current", not the "applied emf."
  • · Replies 16 ·
11K
