Entanglement
- 438
- 13
The title is enough
jtbell said:Look at the list of "Related Discussions" at the bottom of this thread, and you'll find two threads with the same question as yours. One of them has 24 responses, which looks promising!
I know the observation, but I can't figure out its reason. Bio-Savarts law will only guide me to the direction of the field mathematically not logically nor intuitively.UltrafastPED said:It's an experimental observation, first made in 1820. See http://inventors.about.com/od/lessonplans/ht/magnetic_fields.htm
The Biot-Savart law was inspired by this and other observations.
See http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/biosav.html
So you should be able to start with the Biot-Savart law, and get back to Oersted's observation.
How isn't it a physics question if I want a deeper answer??WannabeNewton said:It's simply due to the cylindrical symmetry of the system.
ElmorshedyDr said:I know the observation, but I can't figure out its reason. Bio-Savarts law will only guide me to the direction of the field mathematically not logically nor intuitively.
ElmorshedyDr said:Why isn't there any poles
Why are the lines rotating around the wire and not ending or beginning at certain poles ?
Thanks a lot !jtbell said:Here's an argument that the magnetic field around a straight wire has to be in circles simply because of the symmetry of the source:
https://www.physicsforums.com/showthread.php?p=4711973#post4711973
What does it mean that circumference is directly proportional to the intensity ? Since there are infinite concentric circlesmfb said:2πr is just the exact circumference of a circle with radius r.
There is nothing "maximal". The (theoretical, ideal) field extends to infinity.
That is a weird way to reduce Ampere's law.
mfb said:As I said, that is a weird way to reduce Ampere's law. You could read it "with larger current, you get the same field strength (which you omitted) at a larger radius".
And constant factors like 2π are irrelevant anyway if you look at proportional quantities.
Yes.ElmorshedyDr said:I think Br \propto I seems more meaningful
their product is directly proportional to the intensity
?ElmorshedyDr said:how is B at the center of a circular loop and a solenoid derived from :
Ampere's circular law
B = \muI / 2\pir
