Why is the Riemann Sum 1 + 6i/n and Not 1 + 3i/n?
The Riemann sum for the solid with a rectangular base bounded by the x and y-axes and the lines x=2, y=1, is correctly expressed as \(\sum_{i=1}^{n} \frac{2}{n} \left(1+\frac{6i}{n} \right)\). The height of the solid is defined as \(1+3x\), leading to the conclusion that the term \(1+\frac{6i}{n}\) arises from evaluating the function at the right edge of each partition. The misunderstanding regarding the height being \(1+\frac{3i}{n}\) stems from not recognizing the correct evaluation point of \(x\) within the Riemann sum formulation.
  • Understanding of Riemann sums and their applications in calculus
  • Familiarity with the concept of definite integrals
  • Knowledge of partitioning intervals in calculus
  • Basic algebraic manipulation of functions
  • Study the properties of Riemann sums and their convergence to definite integrals
  • Learn about the Fundamental Theorem of Calculus and its relation to Riemann sums
  • Explore the concept of evaluating integrals using different methods, such as the trapezoidal rule
  • Investigate the implications of choosing different points (left, right, midpoint) in Riemann sums
Students and educators in calculus, mathematicians interested in integral approximations, and anyone looking to deepen their understanding of Riemann sums and their applications in volume calculations.
Houdini1
Question:
A solid has a rectangular base that lies in the first quadrant and is bounded by the x and y-axes and the lines x=2, y=1. The height of the solid above point (x,y) is 1+3x. Find the Riemann approximation of the solid.
Solution:
I already know that the solution is [math]\sum_{i=1}^{n} \frac{2}{n} \left(1+\frac{6i}{n} \right)[/math]. What I don't see is why it's 1+(6i)/n and not 1+(3i)/n. Volume can be generalized to be the area of the base times the height, so for this problem I have something like [math]x*y*f(x)[/math]. Of course x is changing so I must rewrite this.
For any partition where we approximate the volume between x_1 and x_2 the length will be [math]\Delta x=\frac{2}{n}[/math] The y value is a constant 1, so won't need to be written explicitly as far as I can see. I know this part is incorrect but it seems to me that the height should be [math]1+\frac{3i}{n}[/math], but I know that since we haven't defined where [math]x_i[/math] is in each partition (it could be the left value, middle value, right value or anywhere) then I'm really stuck here.
EDIT: Now that I think about it more since we haven't defined what n is we don't know what i/n either and i/n will change according to how many partitions we take. So am I correct in thinking that [math]f(x_i)=f(i\Delta x)[/math]? If so this makes sense now.
Houdini said:
Question:
Solution:
For any partition where we approximate the volume between x_1 and x_2 the length will be [math]\Delta x=\frac{2}{n}[/math] The height is a constant 1, so won't need to be written explicitly as far as I can see. I know this part is incorrect but it seems to me that the height should be [math]1+\frac{3i}{n}[/math], but I know that since we haven't defined where [math]x_i[/math] is in each partition (it could be the left value, middle value, right value or anywhere) then I'm really stuck here.
This is just a one dimensional integral/Riemann sum problem in disguise, since the height is a function of \(x\) only and the interval for \(y\) is of width \(1\), so we seek:
\[\int_{x=0}^2 (1+3x) \; dx\]
We divide the \(x\)-interval \([0,2]\) into \(n\) strips each of width \(2/n\), then the area of the \(i\)-th strip is approximately:
\[A_i=\frac{2}{n} \times \left(1+3 \times \frac{2\times i}{n}\right)\]
where we are using the \(x\) value of the right edge of the \(i\)-th strip (\( (2 \times i)/n \) ) as our approximate value of \(x\) in the formula for the height of the for the strip.
Then the right Riemann sum is:
\[S_n=\sum_{i=1}^{n}A_i={\Large{\sum_{i=0}^{n-1}}}\left[ \frac{2}{n} \times \left(1+3 \times \frac{2\times i}{n}\right)\right] \].
CB
Almost makes perfect sense, just would like clarification about the [math]f(x_i)=f(i \times \Delta x)[/math] part. If that's true than I see [math]f(x_i)[/math] as [math]\left( 1+ 3 \left[ i \times \frac{2}{n} \right] \right)[/math]. I know that's just rewriting what you posted but writing it this way seems to confirm my stated assumption.
That's well put that this is a disguised single variable integral too.
  • · Replies 16 ·
  • · Replies 24 ·
