Why Is There a (dBx/dx)*(dx/2) Term in Divergence Theorem Proof?
The discussion revolves around understanding a specific term in the context of the divergence theorem as presented in "Electromagnetic Fields and Waves" by Lorrain and Corson. The focus is on the outward flux through a closed surface defined by an infinitesimal volume element and a vector field with components dependent on spatial coordinates.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the origin of the term "+ (dBx/dx)*(dx/2)" in the expression for outgoing flux. Some suggest it arises from averaging the magnetic field over an interval, while others reference Taylor expansions to justify the term's presence.
There is an ongoing exploration of the mathematical reasoning behind the term in question, with participants providing insights into Taylor series and average values. Some participants express confusion about the factor of 2 and its implications for the flux calculation, indicating a productive dialogue without a clear consensus yet.
Participants note the importance of evaluating the magnetic field at specific points within the volume element and the implications of using averages in the context of the divergence theorem. The discussion also highlights the need for clarity on the setup of the problem and the definitions being used.
retupmoc
Im having a bit of a problem understanding the crucial part of the divergence theorem from Electromagnetic Fields and Waves by Lorrain and Corson. Ill try descibe the set up of the problem 1st and see if anyone can help me in any way before i continue with the electromagnetism course I am doing as i want to be comfortable with the vector algebra.
The book considers the outward flux through a closed surface, in this case an infinitessimal volume dx dy dz and a vector B whose components Bx, By, Bz are functions of x,y,z. The value of Bx at the centre of the right-hand face may be taken to ve the average value over that face. Through the right-hand face of the volume element, the outgoing flux is
dΦR = (Bx + (dBx/dx)*(dx/2))dydz
This is the bit I am puzzled at, i understand dydz is the area element and why its the x-component of the vector we use in the line integral but I am not getting where the "+ (dBx/dx)*(dx/2)" is coming into the scene. Any suggestions?​
Shouldn't it come from:
[tex]\frac{B_{x}(x+dx)-B_{x}(x)}{2}[/tex] which is indeed the average of the magnetic field over the interval (x,x+dx)...?
Daniel.
P.S.And the Taylor expansion to first order.BTW,it should be partial derivative wrt "x"...
Thats what I've seen elsewhere, how do i do the Taylor expansion? Yeah i know its a partial derivative but I am unsure how to do equations etc in my posts so can only keep it basic
Well,you can approximate the Taylor series to the first term:
[tex]B_{x}(x+dx,y,z)-B_{x}(x,y,z)\approx \frac{\partial B_{x}(x,y,z)}{\partial x} dx[/tex]
and i believe that's how it's done.
Daniel.
Thanks think I've got a better idea now
just the 1 more question. what happens to the factor of 2. If the average magnetic field over the interval is B(x+dx)-B(x)/2 then do the Taylor expansion, would that not make the x-component of the flux 1/2(dBx/dx)dV or is this only the outgoing flux through the right hand surface of the volume element, and the outgoing flux through the left side gives 1/2(dBx/dx)dV also
I don't have my copy of Lorrain and Corson handy... but is "B(x)" being evaluated at the center of the box or at a corner of the box of size (dx) x (dy) x (dz)? This might explain the factor of 2.
In addition, you are setting up an area-integral [which can be read expressed as a volume-integral].
Note that only the x-component flows through the area element dydz.
(In other words, the normal to that area element is along the x-axis.)
The interval is centered around x. The interval goes from x-dx/2 to x+dx/2.
The average value of the x-component of the magnetic field is just [tex]B_x(x)[/tex].
If you take the taylor series of [tex]B_x(x)[/tex] about x...
[tex]B_x(x+h) = B_x(x) + B_x'(x)h +...[/tex]
So you can plug in h=dx/2 or h=-dx/2 to get [tex]B_x[/tex] at the right hand surface or left hand surface.
16K
9K
