Why is wave intensity defined as displacement^2 rather than just its magnitude?
Wave intensity is defined as displacement squared because intensity represents power delivered per unit area, which correlates with energy per unit time per unit area. The energy carried by a wave is proportional to the square of its amplitude, making squaring the displacement necessary for accurate calculations. This relationship is particularly evident in mechanical waves, where each point undergoes simple harmonic motion (SHM). Simply using the magnitude of the wave would not accurately reflect the energy involved. Thus, the squared displacement is not merely a convention but a fundamental aspect of how wave energy is quantified.
jeebs
pretty straightforward question. for a long time I've been blindly calculating that intensity is (displacement from zero)^2, but never questioned why.
So why is this? I get that by squaring you get a positive value, which helps in, say, quantum probability calculations, but what's wrong with just taking a magnitude of a wave at a given point and calling that the intensity?
is it just one of our arbitrary conventions in physics or is there some real reason?
Science news on Phys.org
Intensity is a classical concept, so let's leave the quantum realm alone for now.
To answer your question, we have to look back at what intensity is defined as: crudely, it is power delivered per unit area (albeit perpendicular to the propagation), which works out to energy per unit time per unit area.
Now, the energy carried by a wave is proportional to the square of its amplitude. This can best be illustrated with mechanical waves, such as a wave on a rope, in which every point is essentially in SHM. Consequently, intensity of a wave is also proportional to (amplitude^2) of the wave.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
