Curious_Dude
- Messages
- 19
- Reaction score
- 0
Hello everyone!
Recently, I decided to start building my own home-made projects, starting at a small scale level. The first task I gave myself was to create an electromagnet. In a few minutes... done; beautiful. Easy as eating cake. However, I wanted to (just for the heck of it) make it turn on and off at a distance, so I started reading up on remote control, radio, microchips, electric motors, and all kinds of other things. I eventually went with trying to create a radio-controlled electromagnet.
Realizing that finding parts to create a radio control system was a pain, I decided to buy a radio-control car, and use salvaged parts from there. I managed to get the microchip out of there, and remove it from the dual electric motors that it was attached to (successfully removed it with the wires still intact). Then I attached the microchip to a dual D-battery set up, which when tested with an amp meter (while using one of the radio-control joysticks) worked amazingly well. So everything was done good and fine, and everything worked well. I double tested everything I could think of, in every possible way I could think of.
However, when I put the electromagnet into the circuit, and used the RC joystick, everything wasn't so jolly. The electro-magnet didn't work, and worst of all, the amp meter wasn't even picking up anything in terms of current!
Basically, all I did was attach the ends of the looped wire (that is on the electromagnet) to the wires of the microchip (that used to be attached to one of the electric motors). And theoretically, in my mind, it should of worked, but in reality, nothing happens. I've just been rattling my brain about what could be causing this not to work!
And I've tried everything, from switching wires, to trying different joysticks and testing both at the same time, in every way possible. I even tried adding a resistor in between one of the EMC wires and microchip wires: nothing. I tried wiring and rewiring everything. And I tested everything again, many times; everything works perfectly. I mean, the microchip is receiving the RC commands, and is sending current to the right place, it's just that something happens to the current, and then the electromagnet just doesn't work!
I really have tried everything I could think of; if anyone could help me out here (maybe I missed something, or maybe my concept is off), then I would be truly grateful.
Thank you for reading,
- Curious_Dude
- Curious_Dude
