Why isn't there light exiting anywhere else?
  • Thread starter Thread starter yosimba2000
    Light
The discussion centers on the behavior of light as it passes through a block of plastic with varying density, specifically comparing a laser to a lightbulb. When a laser is used, it follows a specific path that minimizes travel time, adhering to Snell's Law, which explains why light refracts at certain angles. Unlike a laser, a lightbulb emits light in all directions, illuminating multiple exit points on the other side of the plastic. The laser's focused beam results in limited exit points due to its narrow emission angle, contrasting with the omnidirectional output of a lightbulb. This difference in light emission explains why a laser does not illuminate all possible exit points like a lightbulb does.
yosimba2000
In this video, a laser is being shined through a block of plastic with changing density.
At time 0:13, light enters the plastic and exits. The light takes the path the way it does because that path provides the least time to arrive at the current exit
But why doesn't the laser also take another path to arrive at another exit below the current exit? Surely there is ANOTHER path of least time that would allow light to exit at another position?
I imagine that instead of a laser we use a lightbulb, the whole block of plastic would be illuminated and each possible exit point would have light passing through it. What's up with a laser?
Likes OmCheeto
Science news on Phys.org
In the end, you're asking why, when a ray of light enters water, it gets refracted at a certain angle, not at others. That's essentially Snell's Law, so I would recommend reading that.
Yes, I know of Snell's Law, but what I'm confused about is why the light doesn't get reflected everywhere to cover all possible points.
If I shine a regular lightbulb through a piece of plastic, all possible exit points on the other side of the plastic are illuminated. Not so with the laser, as shown in the video.
The laser can only produce light in one direction?
The intensity of light from a laser is almost entirely contained within a thin beam than only slowly spreads out as the light travels. Only a very small amount of light emerges at a wide angle from the laser. This is unlike a regular light bulb where light is being emitted in every direction from each point on the surface of the filament (or phosphor coating if we're talking about fluorescent lights).
Likes davenn
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
