Why mannitol solution 0.05% has opalescence?how to delete it?
  • Thread starter Thread starter tzhisun
    Delete
The discussion centers on the opalescence observed when mannitol is dissolved in water, raising questions about whether this indicates the formation of a colloid. It is suggested that if the concentration of mannitol is below its solubility limit of 0.05%, impurities may be responsible for the opalescence. Recommended solutions include filtration, gentle heating to precipitate impurities, or using methods like crystallization or chromatography for purification. The importance of ensuring the purity of the distilled water used is also emphasized, as impurities or stabilizing agents could contribute to the colloidal state. The supplier's information on mannitol's purity is deemed crucial for resolving the issue.
tzhisun
when i add mannitol into water, the solution has opalescence. Does the solution forms colloid? Then how should I do to delete it? Thank you very much...:smile:
Chemistry news on Phys.org
Look in a reference source for the solubility of mannitol in distilled water. If it is greater than 0.05% an impurity may be causing the opalescence. If so try filtration to remove it, or gentle heating to precipitate it. Purification by crystallization or chromatography may be in order. What does the supplier say about the purity?
thanks so much! I think the purity has no problem. it's from Roquette. what puzzles me is that why does the phenomenon should happen while the concentration is much lower than its solubility. And the method you provide helps me a lot. :smile:
Opalescence usually is due to particles large enough to reflect light, possibly a colloidal solution. If so remove the colloid by filtration, centrifugation, precipitation, etc., make sure your distilled water is pure. Since mannitol is very water soluble, the opalescence is likely due to an impurity, or conceivably a stabilizing agent keeping some mannitol in the colloidal state. The supplier should give info on purity. If necessary purify by recrystallization, chromatography, etc. Good luck.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
