Why normal force always prependicular?
The normal force is defined as the force acting perpendicular to a surface in contact with an object, such as a book resting on a table. This force counteracts the weight of the object, which acts downward due to gravity. The discussion clarifies that the term "normal" is mathematically synonymous with "perpendicular," emphasizing that the normal force is not aligned with the weight but rather acts at a right angle to the surface. Additionally, the conversation highlights the distinction between normal forces and other force components, such as tangential forces.
  • Understanding of basic physics concepts, particularly forces and motion.
  • Familiarity with the definitions of normal and perpendicular in mathematical contexts.
  • Knowledge of gravitational force and its effects on objects.
  • Basic comprehension of vector components in physics.
  • Study the concept of vector decomposition in physics to understand force components.
  • Learn about gravitational forces and their impact on objects at rest and in motion.
  • Explore the principles of static and dynamic friction in relation to normal forces.
  • Investigate the role of normal forces in various physical scenarios, such as inclined planes and circular motion.
Students of physics, educators teaching mechanics, and anyone interested in understanding the principles of forces and motion in real-world applications.
supremesaiyan
why normal force always perpendicular?
why doesn't be in the same direction of the affecting force?
like a mass on a sliding wall why doesn't be opposite the direction of the weight?
Normal is a mathematical term that means perpendicular.
The normal reaction that you seem to be referring to is called normal since it acts perpendicular to the bodies weight (e.g. the normal force on a book by the table it is sitting on is perpendicular to the book). Hence, it is in the opposite direction of the applied force (the objects weight in this case).
CS
Oops, stewartcs:
A normal force acts perpendicularly with respect to a given surface onto some object in contact with that surface.
arildno said:
Oops, stewartcs:
Isn't that what I said?
CS
CS
CS
You say:
1.
This doesn't have much meaning; normal since it is PERPENDICULAR to the body's weight??
It is normal to the surface if the wall is vertical, and INCIDENTALLY normal to the body's weight.
2.
How can anything be perpendicular to a BOOK??
3.
Now, you contradict yourself with respect to the example in 1, and not the least in the OP's question:
arildno said:
You say:
1.
2.
3.
Oh...LOL...I see what you mean...that did come out wrong initially...
My example is of a book lying flat on a table. The book has some weight (mg) to it. There is a normal force from the table (opposite in direction from mg) applied to the surface of the book which is lying horizontally on the table. Thus making the normal force perpendicular to the surface of the book.
CS
As mentioned in math and physics, normal means perpendicular to something, either a surface or direction of travel.
Forces aren't always "normal", but generally forces can be separated into components tangental and perpendicular to a surface.
In the case of an object moving in a specific direction, then the perpendicular component to a line is a plane, so you need additional criteria to separate the components of force on that plane. In some cases, like an electron moving in a magnetic, the electron has a direction, the field has a direction, and the normal force has the remaining direction.
  • · Replies 49 ·
  • · Replies 20 ·
  • · Replies 252 ·
9K
