Why not just use B rather than dB?
  • Thread starter Thread starter xorg
    Db
The decibel (dB) is used instead of the bel (B) to simplify measurements by allowing for smaller, more manageable values, as the bel represents a larger power ratio. The decibel is a logarithmic unit that helps express sound intensity in a way that aligns with human perception, where a change of about 1 dB is the smallest increment most listeners can detect. The use of base 10 logarithms in a decimal system further facilitates easier calculations and comparisons. Historically, the bel was introduced first, but the decibel became more practical for everyday use. The discussion highlights the importance of these units in accurately conveying sound levels and their historical context.
xorg
Hi,
My question is very simple but I have not found on google. Why Decibel unit employs Deci?
I know Deci = 0.1, but why not just use B rather than dB? Is there some historical reason?
Thank you, enjoyed the forum, it is my first post.
The decibel was proposed first, it was originally called the Transmission Unit. The Bel was defined later because it is a straight power ratio.
http://en.wikipedia.org/wiki/Decibel
xorg said:
Hi,
Hi xorg. http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
A bel is the log to base 10 of a power ratio. In practice, if we used bels we'd frequently be relying on a decimal fraction for common measurement comparisons. By using the much smaller measure, decibel, we lift the common measures into integers.
It's a bit like expressing your height in metres. The all-important part is the fractional bit, but we conventionally tend to pay less heed to that part of a number.
Sensitivity of perception is the most natural reason
Ah, that reminds me--I've heard it said that a 1decibel step in loudness is about the smallest increment that even the most astute listener can discern. Most of us can perceive a change in sound only if it's at least 2dB. I'm in no position to argue with that figure.
The neper is more fundamental than the bel. It is the natural log of a power ratio. http://en.wikipedia.org/wiki/Neper
It is because we use a base 10 number system that we used base 10 logarithms to keep the conversions simple.
Hence in the days of the slide rule, the bel dominated rather than the neper.
Somewhere in my collection is some old German calibration equipment for telephone bearers that is calibrated in nepers.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
