Why should arguments of certain functions be dimensionless?
  • Thread starter Thread starter Nirmal Padwal
    Functions
Arguments of certain functions must be dimensionless to maintain the additive nature of physical quantities like mass, length, and time. If the arguments are not dimensionless, operations such as exponentiation or trigonometric functions become invalid, as they cannot be summed correctly. The discussion highlights the importance of the Buckingham pi-theorem, which states that physical relationships can be expressed as functions of dimensionless quantities. It also emphasizes that while individual terms may not be dimensionless, the overall expression must adhere to dimensional consistency. Understanding these principles is crucial for solving physical problems accurately.
Nirmal Padwal
Solutions to physical problems often involve functions like
$$ cos u, sin u, e^u, ln u, · · · $$
where the argument ##u ## is a scalar that depends on physical quantities such as time,
frequency, mass, etc. Explain why u must be dimensionless (that is, independent of
the system of units used for mass, length, and time).
This is my approach:
These quantities namely mass, length, and time, are all additive in nature. ##2 m + 3m = 5 m ##. If the argument of the functions mentioned in the problem statement is not dimensionless, then mass, length or time do not remain additive in the image space of the functions. ## e^{2 m} + e^{3m} \neq e^{5m}##
Furthermore, if the arguments are dimensionless, the functions which were originally dimensionless have to be now themselves will have to be associated with physical quantities.
Is this reasoning valid?
##\cos(u)=1-u^2/2+\ldots## so you can not summate 1 and dimensional variable
Regarding log the situation is little bit more interesting. You can write ##\log a-\log b## if ##a,b## are of the same dimension
Likes Nirmal Padwal, etotheipi and cnh1995
Thank you for your answer. It makes more sense than mine. So was my approach completely incorrect?
No. You could say exactly the same if the arguments are dimensionless.
The thing you are asked to prove is not strictly true. Consider e.g. ##e^{\lambda t}##, where t is a time and λ is a rate, like fissions per unit time. ##\lambda t## is dimensionless, so ok. But we could rewrite it as ##(e^{\lambda })^t##. This appears to violate the principle.
The resolution is that ##e^{\lambda }## has dimension, but rather a strange one. Where λ has dimension T-1, we could write the dimension of ##e^{\lambda }## as ##e^{T^{-1}}##. When this is subsequently raised to the power of t, provided the time units are the same, it all comes out in the wash.
Likes Nirmal Padwal
Thank you for answering
The main result in dimensional analysis, the Buckingham pi-theorem, explains this. It is a quite powerful statement about the possible forms of physical relationships.
Edit: I also wrote an insight on this some time ago.
Likes etotheipi
I don't see that it follows from that theorem. See post #4.
I should also have discussed the trig functions.
If we are defining cos(x) as the limit of ##1-\frac 1{2!}x^2+\frac 1{4!}x^4..## then clearly x must be dimensionless since the different powers of x would have different dimension.
... unless, that is, it has some funny kind of dimension such that it becomes dimensionless when raised to an even power. See https://www.physicsforums.com/insights/can-angles-assigned-dimension/
It does, the Buckingham pi-theorem essentially states that any physical relationship must be possible to write as a level curve of a function of a number of dimensionless quantities ##f(\pi_1,\ldots,\pi_k) = 0##. This means that if the variable I am interested in is in ##\pi_1## only (this can always be arranged), then
\pi_1 = g(\pi_2, \ldots, \pi_k),
where ##g## is a dimensionless function of dimensionless variables. In other words, if you are interested in the variable ##a## where ##\pi_1 = a/b## (##b## being some combination of other variables that make ##\pi_1## dimensionless), then
a = b g(\pi_2, \ldots, \pi_k).
Here, since ##g## is a dimensionless function of dimensionless variables ##\pi_i##, you have a normalising variable of the correct dimension (##b##) multiplied by a dimensionless function of dimensionless combinations.
Edit: In other words, any functional form (apart from a multiplicative factor) must be a function of dimensionless parameters.
Ok, my mistake was failing to read this part properly: "Solutions to physical problems".
I am used to performing the sanity check that if e.g. I have a term eexpression then expression should be dimensionless. But I am aware that in principle it need not be, because the term as a whole need not represent a physical quantity (as in my example in post #4).
  • · Replies 16 ·
64K
19K
  • · Replies 19 ·
