Why the negative sign in the current continuity equation
  • Thread starter Thread starter jeff1evesque
    Conservation Law
jeff1evesque
Statement:
Couls someone explain the following equation to me:
[tex]\int \int_{surface} \vec{J} \cdot \vec{ds} = -\frac{\partial Q_{enclosed}}{\partial t},[/tex] where [tex]\vec{J_{v}}[/tex] is the electric current density. Question:
I am more confused with the term on the right side. The left side simply determines the current density on some surface, and that is why it is a surface integral.
But the right side says the surface has a negative current density. Why can't we just take the negative sign off, and assume if the resulting answer is less than the initial conditions, then the charge density in a particular region has decreased? Can someone either explain this to me, or provide an example.Thanks,Jeffrey
It's because ds is the OUTWARD pointing normal of the surface. If the current flow is outward from the sphere then the left side is positive because J.ds is positive. But that corresponding to decreasing charge in the sphere.
So the right term corresponds to how much charge from the enclosed surface has left per unit time t. Not how much charge remains in the closed surface after a unit time?
