Why the temperature of a moving jar of gas doesn't increase
The discussion centers on the concept of temperature in relation to the motion of a gas contained in a jar. Participants clarify that the temperature of the gas does not increase despite an increase in average velocity because temperature is defined as the average kinetic energy (KE) of the gas molecules, which is independent of the bulk motion of the jar. The reference frame used to measure temperature is crucial, with the center of mass frame being the most relevant. The conversation also touches on the implications of measuring temperature with thermometers and the effects of the Doppler effect on perceived temperature.
  • Understanding of kinetic theory and its relation to temperature
  • Familiarity with reference frames in physics
  • Knowledge of the Doppler effect and its impact on measurements
  • Basic concepts of thermal energy and its distinction from bulk motion
  • Explore the principles of kinetic theory of gases
  • Study the concept of reference frames in classical mechanics
  • Investigate the Doppler effect and its applications in measuring temperature
  • Learn about the differences between thermal energy and kinetic energy in thermodynamics
Students of physics, educators teaching thermodynamics, and anyone interested in the fundamental principles of temperature and kinetic energy in gases.
RubinLicht
Why doesn't the temperature of a moving jar of gas increase?
Average KE is proportional to temperature
This is just an extension of a problem my friend sent me, and I'm stuck on why even though average velocity is increasing, the temperature does not increase.
Think about the reference frame that makes sense to use when talking about the random KE of the molecules of an object.
And realize that the macroscopic velocity of an object is always relative to something. Relative to your chair, you are at rest. Relative to a moving train, you might be moving at 70 mph. Relative to the sun... and so on.
The frame in which the average velocity is zero, so the jar.
RubinLicht said:
The frame in which the average velocity is zero?
Right. (Also called the center of mass frame.)
Ah thanks, makes much more sense than my friends explanation haha
So shouldn't the question state, just to be clear, that the thermometer is moving with the jar?
Good point. :biggrin:
the question makes no reference to thermometers!
Quite so, but how is the temperature to be measured/defined? My point is that it affects the answer.
If the gas is heteropolar, you would be able to measure its temperature externally by infrared radiation. This would show an elevated temperature if you stand in front of it but a lower one if measured from behind, because of the Doppler effect. Measuring all around and averaging, you would still see a slightly higher temperature because of the increased total energy (KE).
I am viewing temperature (of a gas) as the average translational KE of molecules which has nothing to do with how temperature is measured. It is a mathematical concept from kinetic theory. What thermometers 'measure' is a different matter.
The usual view is that temperature is a measure of the thermal energy. Bulk motion does not contribute to that.
The question setter clearly agrees with that. Your view makes the question wrong, and makes it hard for observers to agree on temperature.
thankyou for pointing out how wrong I have been.
  • · Replies 21 ·
