Is Using Multi-Valued Operators for Proofs Risky?
  • Thread starter Thread starter MatheusMkalo
Using multi-valued operators in proofs can lead to incorrect conclusions, as demonstrated by the distinction between (-3)² and √9. While (-3)² equals 9 and √9 equals 3, the square root function is defined to yield only the positive root, making √((-3)²) equal to 3, not -3. The discussion emphasizes that √(x²) is equal to |x|, not ±x, which can cause confusion when solving equations. It is crucial to verify that solutions fit the original equations to avoid extraneous results. Misunderstanding these principles can result in flawed mathematical reasoning.
MatheusMkalo
(-3)² = (\sqrt{9})² --> True
-3 = \sqrt{9} --> False
Wolfram Alpha result: False
Mathematics news on Phys.org
Because -3 doesn't equal 3?
We had a thread about this recently. The point is that \sqrt{x^2}\neq x. The square root of x is defined as the unique POSITIVE number who's square is x. Thus \sqrt{(-3)^2} is the unique positive number who's square is (-3)^2=9, obviously, this number is 3.
Thus, in general, we have that \sqrt{x^2}=|x|.
So, your first equation:
(-3)^2=(\sqrt{9})^2
is true, since (-3)^2=9and \sqrt{9}=3 and 3^2=9
But when taking the square root of both sides we get
\sqrt{(-3)^2}=\sqrt{(\sqrt{9})^2}
which evaluates to 3=\sqrt{9}, which is perfectly true!
Building on what micromass just said, use the horizontal line test to find out that there is no unique inverse except for the case when x = 0.
When you "undo" a squared operation, it is not as simple as just removing the little "2" superscript.
Really? In my classes, we've always used \sqrt[]{x^{2}}=\pm x
No, this is wrong. The square root function is defined to be the unique positive square root of the number. \sqrt{9}=3 and if \sqrt{9}=\pm3 then I have no clue why we would write such answers as x^2=9 \rightarrow x=\pm \sqrt{9} when the square root is already \pm :wink:
And this is why when you use a multi-valued operator to prove something, you always have to check and see if the answer fits the original equation. Or you'll end up with extraneous or wrong solutions like -3=3.
