Will O' Clocks Show Different Times?
  • Level: Graduate
  • Thread starter Swapnil
    Sr
31 replies · 5K views · last reply
Suppose O' is a frame that observes an infinite grid with all the clocks synchronized to O' itself.
Now, O is a frame (me) who has a relative speed with respect to O' (thus all the other clocks of the grid as well)
How will my observation of the times be affected by my motion?
Specifically, suppose the origin (both space and time) was the event when O' and O touched each other
Assuming O is going towards the x-axis of the grid, what will the observed time of a general grid point be according to O?
Further let the x-axes of the two grids be parallel, likewise for the y- and z-axes, and let the relative speed v of O' with respect to O be in the +x direction.
I assume you mean that the origins (x=y=z=0 points) of the two grids coincide at t=t'=0.
Then two clocks whose x'-coordinates differ by [itex]\Delta x'[/itex] in O' (and which are synchronized in O'), will be observed in O to be out of synchronization by an amount
[tex]\Delta t' = \frac{v \Delta x'}{c^2}[/tex]
with the clock that is in the "forward" position (with respect to the motion of the clocks in O), having a reading that is behind the other one.
So if the clocks are 1 light-second apart in O', and are moving at 0.5c (0.5 light-seconds per second) in O, then in O they will be observed to have readings that are 0.5 second apart, and decreasing as you proceed in the +x direction. All O' clocks with the same x' but different y' and z' will have the same reading in O.
