Will the kinetic energy operator change with a variable shift?
3 replies · 2K views
Konte
Hello everybody,
A special problem constrain me to make a variable change in my Hamiltonian operator, so with the kinetic energy operator, I have a doubt.
The variable change is: ## \theta \longrightarrow (\theta + k) ## (where ##k## is a constant).
And the kinetic energy operator change as :
$$ \hat{T}_{old}=\frac{-\hbar^2}{2m} \frac{\partial}{\partial \theta^2} \,\, \longrightarrow \,\, \hat{T}_{new}=\frac{-\hbar^2}{2m} \frac{\partial}{\partial (\theta+k)^2} $$
When ##\hat{T}_{old}## and ##\hat{T}_{new}## operate respectively onto a function, say ##\psi(\theta)##, will I have two different results?Thank you very much.
If ##\theta## is an angular variable, such as the ##\theta## in cylindrical coordinates, then that is not the correct expression of kinetic energy. If ##\theta## is a normal cartesian position coordinate, then those operators produce the same result when operating on a function, as you can deduce from the equation ##\frac{d}{d\theta} = \frac{d(\theta+k)}{d\theta}\frac{d}{d(\theta + k)}=\frac{d}{d(\theta + k)}##
This hamiltonian is for a plane rotator (polar coordinate whith fixed-##r##). I should have mentioned inertia ##I## instead of mass ##m##.
So it is about an angular variable ##\theta##. Is something change with respect to your answer in the Cartesian coordinate case?
Thanks.
Yes, if you use ##I## instead of ##m##, the expression is correct. The derivative ##\frac{d}{d\theta}## is equal to ##\frac{d}{d(\theta + k)}## for any variable ##\theta## and constant ##k##.
