Wilson's GF Method (molecular vibrations)
  • Thread starter Thread starter jaejoon89
    Method Vibrations
Wilson's GF Matrix Method can be applied to linear molecules, including linear chains of hydrocarbons, despite some restrictions. While the method is valid for linear geometries, the G matrix elements provided by Wilson, Decius, and Cross are not specifically tailored for such structures, necessitating careful derivation or validation of these elements. The bond angles in singly-bonded hydrocarbons are approximately tetrahedral, complicating the application of the method. Many matrix elements are zero at linear geometry, particularly stretch-bend elements due to orthogonality. This information is crucial for those looking to apply the FG matrix method to linear molecular systems.
jaejoon89
Can Wilson's GF (FG) Matrix Method be applied to linear molecules as well as nonlinear? For example, can it be applied to a linear chain of hydrocarbons? What are some of the restrictions?
I don't see why not. Can you get more detailed?
1. A chain of hydrocarbons is not linear (unless the carbons are triple-bonded). For a singly-bonded chain of hydrocarbons, the geometry of the bonds on each carbon are approximately tetrahedral so the bond angles are about 109 degrees.
2. Yes, the FG matrix method works for linear molecules. However, G matrix elements tabulated by Wilson, Decius and Cross are not written for linear molecules. (For example, they depend on torsion angles which aren't defined at linear geometry), so you might have to derive/doublecheck the validity of your G matrix elements (for guidance on this, see section 4-2 of "Molecular Vibrations" by Wilson, Decius and Cross. For a more modern text on FG matrix methods, I recommend Chapter 10 of "Molecular Symmetry and Spectroscopy" by Bunker and Jensen). Luckily, many of the matrix elements are zero at linear geometry. (For example, all stretch-bend G matrix elements will be zero because these coordinates are orthogonal when the molecule is linear.)
Hope this is helpful to readers of this forum.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
