Wirewound Potentiometer question
  • Thread starter Thread starter ilovescience85
    Potentiometer
The discussion revolves around the use of a wirewound potentiometer in a circuit analysis problem, specifically focusing on the calculations related to its non-linearity and the effects of loading on the output voltage. Participants are exploring the application of Thévenin's theorem and various equations from provided learning materials to analyze the circuit behavior at different tap positions.
  • Homework-related
  • One participant expresses uncertainty about the initial steps to take in solving the problem and questions how to determine the equivalent resistance when the tap is at 50%.
  • Another participant asks for clarification on the use of a specific resistance value in the calculations.
  • There is a discussion about the appropriate equations to use for calculating the output voltage and the non-linearity of the potentiometer.
  • One participant provides a calculation for the total resistance in the circuit and questions the accuracy of their output voltage result.
  • A later reply emphasizes the importance of careful notation and unit management in calculations to avoid errors in more complex problems.
  • Participants discuss the need for understanding when to apply the various equations presented in the learning material, with one expressing confusion about their purpose.
  • Another participant reflects on the relationship between maximum non-linearity and maximum error, indicating that they have calculated maximum error at a specific tap position but are unsure about the differentiation process to confirm this.
  • There is a suggestion to set up ideal output voltage conditions for further analysis, indicating a method to find maximum error through differentiation.
  • One participant expresses confusion regarding the necessity of differentiation after calculating maximum error at a specific tap position.
Participants do not appear to reach a consensus on the best approach to analyze the non-linearity and error in the circuit. There are multiple competing views on the equations to use and the relationship between non-linearity and error, indicating that the discussion remains unresolved.
Participants reference specific pages in the learning material that contain equations relevant to the problem, but there is uncertainty about how to apply these equations effectively. Some assumptions about the circuit configuration and the definitions of variables are not fully clarified, leading to varied interpretations of the problem.
ilovescience85
A Wirewound potentiometer having 300 turns is to be used in the following system (see atached question file)
See attached coursework file
Unsure where to begin. I have converted the circuit in the attached file to a Thévenin equivalent circuit but I'm unsure what figures to use for my Rt when the tapper is at 50%. Would i be right in saying that for the 50% tapper that x would equal 0.5 so (1-x)Rp would be (1-0.5)3kΩ and xRp would be 0.5x3kΩ both equalling 1.5kΩ.
Its the equations for working out the non-linearity which you can see on pages 19-21 of the attached learning material that i cannot follow. Any help would be greatly appreciated.
I have attache two files, one is the question and the other is the learning material given regarding the question.
  • Potentionmeter Loading.pdf
What are you planning to do with the 0.5 kΩ?
I am unsure on which equation I should use, the equations on pages 19 & 20 are obviously the route I should be taking but I'm unsure of where to begin. I attempted to use Vactual = Vt x RL / RL + RT and I got a figure of 5v but this is obviously the linear figure. So do I simply take x as 0.5 and input it to the following equation N(x)=-Vs x (x2(1-x)/ RL/Rt + x(1-x) along with the figures for Vs, RL and Rt?
You have a single, adjustable resistance between the tap and the 20 V source that is in series with two resistances that are in parallel. What is the resistance of the two resistances that are in parallel? What is the total resistance when that is in series with the single resistance?
Parallel resistance is Rt= R2xRL/R2+RL? Series resistance Rt= R1+R2 so parallel Rt= 1.5x0.5/1.5+0.5=0.375 series =1.5+0.375=1.875
I=v\r 20/1.875= 10.67 Vout = Ixr = 10.67 x 0.375= 4.00125v @ 50%tap? Am I miles off?
Looks pretty good. A note on your notation and units: be careful when you're "dropping" the "k" on kΩ and switching to mA rather than A for current; if you go ahead and write those units in, you won't find yourself in trouble with more involved problems where it's easy to lose (or gain) three orders of magnitude in your answers.
Ah ok yeah i'll keep a track on my notation. So my next question is when would all the equations within the learning material be required to be used?
For some silly reason my browser doesn't want to open pdfs when I link to them secondhand, so I couldn't begin to guess
See if these pictures work? this is what is in the learning material when it talks about the loading effect on a potentiometer.
Readable. You understand the equations? And just want to know when to use them? Or, what use you can make of them? Or, why the great religious ritual to demonstrate that a passive voltage divider is non-linear?
My differentation is great but i understand the flow of the equations and that all in all it is simply proving that the voltage divider is no linear and it's max non-linearity is when the potentiometer is 2/3 of the way along it's slider. I think i need to be at a better level of differentation before i can use them, yeah i find there is a lot that within this learning material. Also not a lot of guidance when i comes to wether its purely to show working/understanding or if it will be required for calculation purposes.
I've had to create a graph of tapper % position v output voltage, it's now asking me to calculate the maximum error as a percentage of he true value. Can i simply take the 2/3 position and calucate the error there with respect to true value?
Without doing the math, "that will be left as an exercise for the reader," (how many times have you had that in your face?) it's not obvious that maximum non-linearity is coincident with maximum error. You'll want to set up ideal Vout for no load (infinite resistance across divider output), x or (1-x) times 20 V minus Vout for the 500 ohm load over ideal Vout, and differentiate that with respect to x, looking for its maximum.
So taking the figure i have the maximum error comes out at 50% so i understand that the max error does not coincide with max non-linearity. See attached image. I also understand that there is a point between 50% and 60% tapper position wherer the error will be it's max but I'm unsure how to find the maximum like you've explained above.
The original question just had you doing every 10%. So, presumably that's all they want.
The second derivative of the function I just had you construct will be zero at either maximum or minimum error if you want to pin the error max down exactly.
I'm confused with your above post. If I've calulated that at 50% tapper the error is maximum @ 59.9875% why do i need to do a differentation for x?
15K
10K
