Word problem, interested in the reasoning process
A 6-gallon radiator initially contains a 40% antifreeze solution, and the goal is to determine how much of this solution must be drained and replaced with pure antifreeze to achieve a 65% solution. The correct answer is 2.5 gallons, but some participants struggled with the calculations, initially arriving at incorrect values. Key points of confusion included the proper setup of equations to account for the remaining antifreeze after draining and the amount added back. Ultimately, one user confirmed the correct solution after re-evaluating their calculations. The discussion highlights the importance of careful reasoning in solving percentage problems involving mixtures.
mindauggas
A 6-gallon radiator is filled with a 40% solution of antifreeze in water. How much of the solution must be drained and replaced with pure antifreeze to obtain a 65% solution?
The answer is given:
Ans. 2.5 gallons
Let x be the amount of added pure antifreeze (which is equal to the amount drained from the original solution (or so I presume)).
Thus I reason
40/100*(6) is the amount of antifreeze in the orig. solution
60/100*(6) water
40/100*(6-x) is the amount of antifreeze after the drainage
60/100*(6-x) water
65/100*(6) is the amount of antifreeze in the new solution
35/100*(6) water
I recon that 40/100*(6-x)+60/100*(6-x)+65/100*(6) should be equal to the new full tank, so 6. But after the calculation i get 3,9, not 2,5.
I would be interested in the reasoning here especially, if someone will bother.
Ans. 2.5 gallons
Thus I reason
60/100*(6) water
60/100*(6-x) water
35/100*(6) water
You add x gallons of anitfreeze to the drained solution.
RGV
Could you expand on that? I actually do can't decode what you say...
Look at the first sentence YOU wrote under heading 3.
RGV
How should your insight reflect in the proposed solution? Does it invalidate the reasoning process?
Ans. 2.5 gallons
Thus I reason
60/100*(6) water
60/100*(6-x) water
And (40/100)(6- x) was the amount of antifreeze after the drainage so (40/100)(6- x)+ x= (65/100)(6)
35/100*(6) water
(40/100)(6- x) is the amount of anti-freeze after draining and (60/100)(6- x) is the amount of water so you should add x anti-freeze. You added the total amount of anti-freeze in the radiator so the amount left in after draining is counted twice.
It means that you added the wrong quantity.
RGV
the x value I get is 1,9 so I guess you were not proposing a solution here, but how come it;s not a solution if I have the antifreeze that's left and add only pure antifreeze (x) I should get the amount of antifreeze in the new admixture. But the answer is clearly incorrect.
Once again (40/100)(6- x)+(60/100)(6- x)+x=6 (if that's what you propose (i'm sorry if i misunderstood your intentions)) leads to incorrect answer: 1.2x = 0
No, (40/100)(6- 1)+ (60/100)(6- x)+ x= 6 leads to 6= 6! That equation does not yet use the new percentage.
Can someone help a little more, I need this one sorted out.
mindauggas said:
the x value I get is 1,9 so I guess you were not proposing a solution here...
Double-check your work. I solved the equation in bold and I got x = 2.5.
Indeed I made a mistake.
Thank's to all for helping.
