Calculating Work Along a Path with a Force Proportional to Distance Cubed
The discussion focuses on calculating the work done in moving a particle attracted to the origin by a force proportional to the cube of its distance from the origin. The particle moves along the path defined by y = x² from the origin to the point (2,4). The force is expressed as ||F|| = k(x² + y²)^(3/2), and the challenge lies in converting this force into vector form for integration. The solution involves multiplying the unit vector pointing away from the origin by the cube of the distance, adjusting for the coefficient of friction, and using the appropriate limits for the integral.
  • Understanding of vector calculus and integration
  • Familiarity with forces and work in physics
  • Knowledge of parametric equations and their derivatives
  • Concept of friction and its mathematical representation
  • Study vector calculus applications in physics
  • Learn about parametric equations and their derivatives
  • Explore the concept of work done by a variable force
  • Investigate the effects of friction in mechanical systems
Students in physics or engineering, particularly those studying mechanics and vector calculus, as well as educators looking for examples of work calculations involving non-linear paths and forces.
compliant
A particle is attracted towards the origin by a force proportional to the cube of its distance from the origin. How much work is done in moving the particle from the origin to the point (2,4) along the path y = x^2 assuming a coefficient of friction \mu between the particle and the path?
For the path, set x = t. Thus, y = t^2
\vec{r}(t) = t\hat{i} + t^2\hat{j}
\vec{r}'(t) = \hat{i} + 2t\hat{j}
Because we're going from the origin to (2,4), t goes from 0 to 2.
For the force, we know that:
\left\|F\right\| = {k(x^2 + y^2)}^{3/2}
I want this ideally in vector form, but the best I could come up with:
{\left\|F\right\|}^{1/3} = kx\hat{i} + ky\hat{j}
My main problem is I can't really use {\left\|F\right\|}^{1/3} to calculate \int_{C} {F\cdot dr}. If I could just find a way to express F in vector form, I'm pretty much off to the races. (Because I can then calculate the work done by friction by finding the normal to \vec{r}(t), multiplying it by \mu, and dotting it with \vec{r}'(t) from 0\leq t \leq 2, etc. etc.)
The vector (x*i+y*j)/sqrt(x^2+y^2) points away from the origin in the direction of (x,y) and has length 1. Just take that vector and adjust it's length and direction.
How would I adjust for the "cube of the distance" though ? Looking at the numerator of that unit vector, there isn't much, I think, that one can do with (x\hat{i} + y\hat{j})^3
The cube of the distance is r^3=(x^2+y^2)^(3/2), like you said. If u=(x*i+y*j)/sqrt(x^2+y^2) has length 1, shouldn't r^3*u have length proportional to r^3? What does that vector simplify to? (x*i+y*j)^3 doesn't even mean anything.
(facepalm of realization)
I'd probably multiply r^3 and u together, wouldn't I.
Then slap on the k at the front of the product, and equate it to F.
Sure, where k is going to be negative if you want it to point towards the origin.
  • · Replies 105 ·
  • · Replies 16 ·
