Work done by expansion of liquidfied natural gas to atmosphere
The discussion revolves around calculating the work done by the expansion of liquefied hydrocarbons in a steel can at 40 psi when released to the atmosphere. The user is uncertain whether to approach the problem as isothermal or adiabatic due to the rapid expansion and subsequent cooling. They also seek to determine how much energy a battery would need to replicate the work done by the compressed gas. Despite attempts to analyze the situation from a kinetics perspective, the results were unexpectedly low. The thread highlights a need for assistance in setting up the calculations for this expansion problem.
casts_by_fly
Hi All,
Been try at this for a week now and I know I'm missing something. I'm too far out of university to remember how to do it, but just close enough to know that I should remember.
Anyway, I have a steel can containing a mixture of liquidfied hydrocarbon gasses (butane/i-butane/propane) at 40 psi internal pressure. Most of the hydrocarbons are liquified, though there is some headspace. Additionally there is another fluid in the container that is being expelled by the propellant (they are mixed, but not miscible if it matters). They are released through a valve to the atmosphere in short bursts with time between the bursts for the can to return to room temperature (nominally 300K). How much work does the compressed hydrocarbon do on the other liquid when released to the atmostphere? If I were to replace the propellant with a battery, how much energy would the battery need to hold to be able to get the same work into the other liquid?
I feel like it is an expansion problem, but can't decide between isothermal (because both the internal gas and the released gas return to room temp) or adiabatic (because the expansion is rapid and there is immediate cooling from both the expansion of the gas and the evaporation of liquid to gas in the container). Neither seems to fit though.
I tried to work it out from a kinetics standpoint by figuring out the velocity of the ejecta and the mass ejected, but the number was very low for what I was expecting.
Any help in setting this up?
Thanks,
Rick
casts_by_fly said:
Hi All,
Thanks,
Rick
I'm a little surprised someone has not responded to this, It sounds a lot like some things I have brought up, my math sucks so I won't be of much help, but there are some very sharp people here, just hope I have not worn them down too much.
Bump!
RonL
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
