Solving Incline Problem with Normal Force: 39.36
The discussion centers on solving the incline problem involving a 4.9 kg mass sliding up a frictionless 35-degree incline. The user initially attempted to use normal force and gravitational force incorrectly, leading to an erroneous calculation of work done. The correct approach involves using the sine function for the angle between the gravitational force and the incline, as well as accounting for the negative work done against gravity. The final correct calculation should reflect these adjustments.
  • Understanding of normal force and gravitational force
  • Knowledge of trigonometric functions, specifically sine and cosine
  • Familiarity with the concept of work in physics, defined as W = F * d * cos(theta)
  • Basic principles of motion on an incline
  • Learn about the role of gravitational potential energy in incline problems
  • Study the application of trigonometric functions in physics problems
  • Explore the concept of work done against gravity in various scenarios
  • Investigate the effects of friction on inclined planes and how to calculate work in those cases
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to clarify concepts related to forces on inclined planes.
momoneedsphysicshelp
A 4.9 kg mass slides 3.6 m up a frictionless 35 degree incline. How much work is done by gravity?
I keep getting this question incorrect and I don't know what I'm doing wrong.
W= F*d*cos(theta)
first I tried to use gravitational force to solve it but because of the incline the gravitational force is zero. so I used normal force to solve.
Normal force is 39.36,
then f*d*cos(theta)
39.36*3.6*cos(55)
it would be cos 55 because the angle is in the direction of normal force from the position of the object
it would equal= 39.36*3.6*cos(55)= 81.27
but it is incorrect.
can anyone please tell me where I made a mistake or if there is another way I should be solving this problem?
thanks
Why would the gravity be zero on the incline? Gravity is always present. Being on an incline doesn’t change that.
Are you allowed to do it by potential energy difference?
neilparker62 said:
The angle you need to use is that between the gravitational force and the direction of motion.
I tried that but it was still incorrect
Did you take the sign into account? Remember that gravity is working against the direction of motion here.
I deleted because I saw you did that. But maybe it's just the sign which is wrong since work is done against gravity rather than by gravity.
So what angle did you use? And what answer did you get?
Likes suremarc
Yes, it was still incorrect
The angle I used was the angle in between the direction of gravity and the object itself, but I tried the complementary angle to that and it was still incorrect.
You've tried several things, none of which gave you the correct answer. Can we see your best attempt?
Here are some questions to consider:
a) When a 4.9kg mass falls 1m, how much work is done by gravity?
b) When a 4.9kg mass rises by 1m, how much work is done by gravity?
c) If an object slides a distance 3.6m up a 35º incline, what is its change in height?
Likes Lnewqban and suremarc
An object on an incline does not move in the direction of the normal force. It follows that the normal force does no work on the object. Nor does the normal component of the gravitational force.
Homework Statement:: A 4.9 kg mass slides 3.6 m up a frictionless 35 degree incline. How much work is done by gravity?
Relevant Equations:: W= F*d*cos(theta)
then f*d*cos(theta)
39.36*3.6*cos(55)
thanks
Thank you all fro the help, My mistake was using cosine instead of sin and not considering that gravity would be negative
  • · Replies 57 ·
  • · Replies 22 ·
