Work done by moving electrons through electric potential?
The work done in charging a parallel-plate capacitor to an electric potential of 100 V by moving 4x1019 electrons is not simply calculated using W = q * V due to the non-constant voltage during charge movement. The correct approach involves integrating the voltage, leading to the formula W = (1/2) * Q * V, resulting in a total work of 320 J. This discrepancy arises because the voltage builds from 0 V to 100 V, necessitating the use of average voltage in calculations.
  • Understanding of electric potential and capacitors
  • Basic knowledge of charge and electron properties
  • Familiarity with integral calculus
  • Concept of energy stored in capacitors
  • Study the energy stored in capacitors using the formula U = (1/2) * C * V2
  • Learn about the relationship between charge, voltage, and capacitance in capacitors
  • Review integral calculus, specifically in the context of physics applications
  • Explore the concept of electric fields and their relation to potential difference
Students studying electromagnetism, electrical engineers, and anyone interested in understanding the principles of capacitors and electric potential work calculations.
nghpham
A parallel-plate capacitor is charged to an electric potential of 100 V by moving 4x10^19 electrons from one plate to the other. How much work was done?
Work is then simply equals to -q*deltaV. Q= number of electrons times charge per electron.
W= +4E19 * 1.6E-19 * 100= 640 J
But the answer I was given was 320 J. I don't see a divisible of 2 anywhere that I can account for.
Please help. Thanks.
Welcome to PF!
The conceptual error you're making here is that V is not constant during the movement of the charges. In other words, the 100 V was not always there from the beginning, but rather it built up slowly from 0 V as the charge accumulated. So W = q*V won't work. Instead you need W = ∫qdV = ∫CVdV.
If you haven't done integrals before, then use the following (totally equivalent) method: look up the equation for the total energy stored in a capacitor.
I see the error. Thank you much.
The voltage built up from zero to 100V by transferring the charge. For a capacitor Q is proportional to V so to calculate the work done you need average voltage (V/2) x charge
  • · Replies 22 ·
