Does Static Friction Ever Perform Work?
Static friction does not perform work when there is no displacement, leading to the conclusion that its work can be zero. However, in certain scenarios, such as when multiple objects are involved, static friction can contribute to the overall system's movement, resulting in positive or negative work depending on the direction of the forces. The discussion highlights that the correct answer to the homework question is "e) any of the above," as static friction can perform work under specific conditions. For example, while a rolling ball experiences no displacement, static friction can still affect other connected bodies. Understanding the context of static friction is essential for determining its work in various physical situations.
krugmik
"The work done by static friction can be:
a) positive
b) negative
c) zero
d) nonnegative
e) any of the above
W=F*d
F(friction)= μ *FN
I thought the answer must logically be "c) zero" because static friction has no distance for as soon as movement begins static friction ends and as such there can be no work without distance. This is for a test correction and so my teacher has told me the correct answer is "e) any of the above" but I must explain why. I think it must have something to do with the wording of the question or a special circumstance in which static friction is considered to do work.
See attachment. There is enough static friction between the blocks so they accelerate together. The only force acting on block B is Fs. What is the work of Fs on B if the whole system moves to the right by a distance D?
At the same time, the same static friction force with opposite sign acts on block A. What work does the static friction do on it?
It can happen that the whole system moves to the left, but the external force accelerates the system to the right. What is the work of the friction on the bodies?
For a rolling ball, the displacement is really zero, so the work of Fs is zero.
ehild
  • · Replies 42 ·
