What Is the Potential at the Center of Concentric Metallic Spheres?
The potential at the center of concentric metallic spheres, where the inner sphere has a potential of 10 V and the outer shell has a potential of 5 V, is definitively 10 V. This conclusion arises from the principle that the potential inside a metallic sphere is uniform and equal to the potential at its surface. The confusion regarding a potential of 15 V stems from a misunderstanding of how potentials from multiple sources interact, particularly when considering the electrostatic properties of metallic conductors.
  • Understanding of electrostatics and electric potential
  • Familiarity with the properties of metallic conductors
  • Knowledge of the superposition principle in electrostatics
  • Basic proficiency in using the formula for electric potential, V = kq/r
  • Study the properties of electric potential in conductors and insulators
  • Learn about the superposition principle in electrostatics
  • Explore the concept of equipotential surfaces in electrostatics
  • Investigate the behavior of electric fields within and around spherical conductors
Students studying electrostatics, physics educators, and anyone interested in understanding the behavior of electric potentials in conductive materials.
Yashbhatt
A metallic sphere is placed inside a hollow spherical shell. The potential on the inner and outer spheres is 10 V and 5 V respectively. What is the potential at the center?(The spheres are concentric.)
$$V =\frac{kq}{r}$$
The obvious answer I thought of was 15 V. But the answer in my text was 10 V. I know that it would be 15 V in case of two concentric spherical shells. Does having a metallic sphere make a difference?(I don't think so because for a metallic sphere the charge resides on the surface.)
What would happen if the potential inside the metallic sphere were different from the potential at its surface?
how did you calculate 15 V?
Then some work would be done in bringing the charge from the surface of the metallic sphere to its center. But I don't see how that could be the case.
That's quite simple. You can just assume some quantity of charge on the spheres and then assume that the charges are concentrated at the center. That would yield the work done and the potential easily.
Would the charge carriers in the metallic sphere remain static (stationary, unmoving) if the potential varied anywhere on or in it? Isn't this a problem in electrostatics?
And I don't see the connection between your thread title and your problem statement. You haven't introduced any mechanism where work will be done, or gone through the exercise of calculating the work required to move a charge from infinity to the center. As far as I can tell you just guessed at an answer (15 V).
How do you know this? Can you demonstrate?
Maybe you summed both the potentials.. it's okay. For a metallic sphere potential at any place is same as to the surface. But is it same for a hollow sphere? I am not sure. You may do one thing, be sure about this point first then cone to the rest part.
$$V =\frac{kq}{r}$$
Can you find the equipotential part in this system?
The potential is constant inside a hollow sphere.
When there is net charge present on the sphere, potential due to that charge inside that sphere is constant everywhere.
Doesn't it follow from the superposition principle?
Doesn't this follow clearly from the superposition principle?
Yes. I used the fact in this case.
Consider this situation. There is a charge +q on the surface of the inner sphere and outer sphere is neutral. The potential of outer sphere is kq/r=5V. What will be the potential at the center then?
$$5 + \frac{kq}{r_i}$$ ?
Charge is on the surface of the inner sphere. What will be the potential at it's center then?
If it is properly applied, yes. But you haven't shown how you applied it to arrive at a 15 V potential inside the 10 V sphere.
$$\frac{kq}{r}$$
I simply added the potential due to the two spheres.
Yashbhatt said:
$$\frac{kq}{r}$$
When the charge is on the surface of the sphere, potential at the surface and inside the sphere is same. The sphere is at 10V potential. Potential inside the sphere everywhere should be same. This implies E field inside the sphere is 0.
So?
Yashbhatt said:
So?
So, the potential at the center will be equal to the potential of the inner sphere, won't it? The inner sphere is at 10V. So the potential at the center is also 10V.
What about the potential due to the outer sphere?
Outer sphere is neutral. Potential of the outer sphere is 5V "due to" the charge on the inner sphere.
I think that's where I had gone wrong.
But consider this case : If you had two concentric spherical shells with charges q1 and q2 and radii a and b, then what would be the net potential at the center? Won't it simply be potential due to sphere 1 plus potential due to sphere 2?
  • · Replies 22 ·
  • · Replies 19 ·
10K
