Work done on a gas when it is compressed quasi-statically
20 replies · 2K views
member 731016
Please below
Pleas see below
For this derivation,
I am not sure why the bit highlighted in orange is not positive since the displacement of the piston is downwards in the same direction as the force applied.
Many thanks!
on Phys.org
It appears to be a notation/convention issue.
When we write ##\vec F = -F {\hat j}## the (unadorned) letter ‘##F##’ means the magnitude of ##\vec F##. This is a common convention – shorthand for writing ##|\vec F|##. Of course, ##F## is, by definition always non-negative.
But ##dy##, it is not a magnitude. It is an (infinitesimal) change in ##y##. It can be positive (an increase in ##y##) or negative (a decrease in ##y##).
In the situation described, ##-PAdy## will be positive because ##dy## is negative.
Edit - typo's
Reply
Callumnc1 said:
Homework Statement:: Please below
Relevant Equations:: Pleas see below
Many thanks!
It appears to me that y is taken to be positive up, so dy will be negative. That is independent of which way the force acts.
Reply
By definition
##d\mathbf{r}=dx~\mathbf{\hat {i}}+dy~\mathbf{\hat {j}}+dz~\mathbf{\hat {k}}.##
Here, ##\mathbf{F}=-F\mathbf{\hat {j}}##.
Therefore,
##\mathbf{F}\cdot d\mathbf{r}=(-F\mathbf{\hat {j}})\cdot(dx~\mathbf{\hat {i}}+dy~\mathbf{\hat {j}}+dz~\mathbf{\hat {k}})=-Fdy.##
Reply
Edit - typo's
Thank you for your reply @Steve4Physics !
So are you saying that the textbook is wrong since ##\vec dr = -dy\hat j##?
Many thanks!
Thank you for your reply @haruspex!
The force acts downwards and the differential displacement is also in the same direction.
Many thanks!
kuruman said:
By definition
Therefore,
Thank you for your reply @kuruman!
But why dose ##\vec dr## not equal ##-dy\hat j##?
Many thanks!
Many thanks!
Because ##\vec r## and ##y## are both positive upwards. ##dy## will have a negative value.
##\vec r=y\hat j##
##\vec r+\vec dr=(y+dy)\hat j##
##\vec dr=(\vec r+\vec dr)-\vec r=(y+dy)\hat j-y\hat j=dy\hat j##
Reply
Callumnc1 said:
Many thanks!
That diagram is a little unhelpful since it makes it look as though dy is a magnitude, so positive. It would have been better to illustrate it as an upward displacement.
Why do you keep mentioning that the force is downward? I already replied that that is irrelevant to the sign on dy in the equation.
Reply
##\vec r=y\hat j##
Thank you for your replies @haruspex!
I will do some more thinking.
Many thanks!
You may have reolved this by now, given the recent posts. But if not...
I'm not saying the textbook is wrong. Nor am I saying ##\vec {dr} = -dy~\hat j##. The correct statement is ##\vec {dr} = dy~\hat j## (where ##dy## happens to be negative here).
Your Post #1 attachment says ##\vec F ·\vec {dr} = - F ~\hat j · dy ~\hat j##.
##\vec F## has been replaced by ##- F ~\hat j## (because ##F## is always positive (a magnitude) and ##\vec F## act downwards).
##\vec {dr}## has been replaced by ##dy ~\hat j## (where ##dy## is negative).
Reply
Thank you for your reply @Steve4Physics!
That helps more. But if ##dy## is negative, then ##dV = A dy## then the volume would be negative?
Many thanks!
kuruman said:
The volume is never negative. The change in volume can be positive or negative.
Thank you, you are very right. Why did the textbook not take write ##dy## as ##-dy \hat j## and assume ##dy## was positive? Is this just a matter of convention?
Many thanks!
Many thanks!
Because they defined y as the height, and dy means the change in y. The height reduced, so dy is negative.
Reply
Thank you @haruspex! That makes sense!
To add a little more...
Yes, it is a convention on the way differentials are used. A differential (e.g. ##dy##) represents a change. We don't limit the change to be only an increase or only a decrease.
For example, you could have a problem where a piston oscillates up and down. You want a single equation - not two equations (one for up and another for down).
I guess if you knew that a differential (e.g. ##dy##) was going to turn-out to represent a decrease in ##y## for a particular problem, to be unambiguous you could write it as '##-|dy|##'. But this seems unnecessarily clumsy. And you loose generality because it would be incorrect if applied to a similar problem where ##y## happens to increase.
Reply
Thank for that @Steve4Physics! That is helpful!
Reply
Hi Everyone,
I am looking into the derivation again,
and I notice that let F = PA when ##dW = - F dy = -PA dy## does this mean that the work is actually slightly greater than ##dW = - P dV## since, initially, the force compressing the piston will be slightly greater than force from the compressed air inside the piston, in order for it to start moving inwards. Are they assuming that the piston is being compressed at a very slow (quasi-static) constant speed so that the forces are balanced?
Many thanks!
kuruman said:
Yes they are. It's in the description of the physical that you posted emphasized in bold.
Great, thank you for your help @kuruman!
