MHB Work energy principle and power
The discussion revolves around calculating the speed of a box sliding down a ramp using the work-energy principle. The height of the ramp is 20 cm, and the box starts from rest, allowing for the application of conservation of energy. The gravitational potential energy (GPE) at the top is converted into kinetic energy (KE) at the bottom, leading to the equation 1/2mv^2 = mgh. By substituting the values for g and h, the mass cancels out, simplifying the calculation. The final speed of the box at the bottom of the ramp is determined to be 2 m/s.
Shah 72
MHB
A box slides down a smooth ramp. The height of the ramp is 20cm and the length of the ramp is 2.5m. The box starts from rest. What is the speed of the box when it reaches the bottom of the ramp?
I don't understand how to solve this. Pls help
Mathematics news on Phys.org
We can apply conservation of energy.
What is the energy due to gravity at the beginning?
What is the kinetic energy at the end?
Increase in KE= loss of GPE
1/2mv^2= mgh
So gpe at the top = m×10× 0.2
GPE at the bottom = 0J
You have the correct equation.
Fill in g and h.
And we can cancel m from both sides.
Fill in g and h.
h=0.2m, so v= 2m/s. I was getting confused with the length of the ramp.
Thanks a lottt!
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
