Work and Energy on a Slope - How Does a Block Move Up with Zero Net Work?
The discussion centers on the application of the Work-Energy Theorem in the context of a block being pulled up a slope with friction at a constant speed. It is established that while the net work done on the block is zero, the block still gains potential energy due to the work done by the tension in the string. The kinetic energy remains unchanged because the work done by the tension is equal and opposite to the work done by gravity. Therefore, the relationship between initial energy, work done, and final energy must account for gravitational potential energy without double counting the effects of gravity.
  • Understanding of the Work-Energy Theorem
  • Knowledge of gravitational potential energy concepts
  • Familiarity with forces acting on objects on an incline
  • Basic principles of friction and its effects on motion
  • Study the implications of the Work-Energy Theorem in different scenarios
  • Explore the relationship between work done by tension and gravitational forces
  • Investigate the effects of friction on the motion of objects on slopes
  • Learn about energy conservation principles in mechanical systems
Students of physics, educators explaining mechanics, and anyone interested in understanding the dynamics of forces on inclined planes.
JackyCheukKi
Work energy theorem please help me
energy initial(of one object) + net work done on the object = energy final??
Guys, I have a problem that really needs you guys to help, I know it is a stupid question but please bear with me:
Context:
You have a block on a slope(has friction) you use a string to pull the block up with constant speed.
Problem:
So according to the network theorem, the work net is equal to the change in kinetic energy, and here we can see that the kinetic energy remains the same and the net work should be zero. But my problem is if the net work is zero, how the heck did the block move up the slope?? if it moves up the slope, it gains POTENTIAL ENERGY right??
isn't Energy(initial) + net work = Energy(final) ?
One must be careful not to count the effects of gravity twice. Either you include the work done by gravity as a force or the change in gravitational potential energy, but not both. (Gravitational PE already includes work done by gravity.)
There are several ways to look at the Work-KE theorem. If you include the work done by ALL forces, including gravity, then no net work is done on the block as it is pulled up the incline. Thus the KE doesn't change. So what? While there's no net work done, whoever is pulling the string is certainly doing work!
On the other hand, you can also view it in terms of energy: Initial energy + work done = final energy. If your energy term includes gravitational PE, then the "work done" means the work done by all forces except gravity. That "work done" will not be zero, since PE increases.
I have a slightly different view from @Doc Al's.
By definition, the net work done on a rigid body is the work done by the net force. Thus, it is equal to the gain in KE. Always. The gain in PE is not considered work done on the body; rather it is work done on the system consisting of the two gravitationally attracted bodies.
You are confusing net work done on the body with the work done by just one applied force, the tension in the string. While the speed is constant, ignoring friction, that is equal and opposite to the work done by gravity.
The precise wording in post #1 suggests the body starts at rest, so you do have to do some net work on it to get it going, though this can be arbitrarily small, depending how much of a hurry you are in. If it also finishes at rest, and there's no friction, you will stop pulling a little before that.
Yes the block gains potential energy but doesn't gain kinetic energy because the net work is zero. Because the net work is zero the work of the tension equals minus the work of the weight. As you probably know the gain in potential energy equals also minus the work of the weight, hence it is equal to the work of the tension. To summarize it:
  • Gain in kinetic energy=net work=0
  • Gain in potential energy=-work of weight=work of tension
