Work-Energy Theorem with Line Integrals
9 replies · 4K views
Vorde
The problem is to prove the work-energy theorem: Work is change in kinetic energy.
Line integral stuff, basic physics stuff.
I'm given the normal definitions for acceleration, velocity and I'm given Newton's second law. I'm asked to show that ##\int_c{F \cdot dr}## leads to ##\frac{1}{2}mv(b)^2-\frac{1}{2}mv(a)^2## along an arbitrary path from a to b defined by ##\vec{r}##(t).
I'm stuck. I got to ##Work = m \int_c{ \frac{d \vec{v}}{d \vec{r}} \, \vec{v} \cdot \vec{v} \, dt}##, but I don't know how to proceed with that pesky dot product in the integrand, and without explicit functions to help me simplify, can anyone help?
Thanks a billion.I'll post my work if it seems like I'm going the wrong way, but I don't know where I would be.
But without knowing an explicit formula for Force, how am I going to find a gradient field?Also, I don't know that my Force field will be conservative, so I can't assume there will be a gradient curve.
The statement of the result that you must prove makes me think that if a potential function [itex]\phi[/itex] exists, then [itex]\phi(c(t))=\frac{mv(t)^2}{2}[/itex]. Maybe you can use this as definition of your potential function??
It has to be conservative since the line integral will be the same regardless of the path you take.
The force doesn't have to be conservative. It's still true. F=ma. a=dv/dt. v=dr/dt. So dr=v*dt. F*dr=m*(dv/dt)*(v*dt). Integrate it. You are making a great deal out of nothing.
Listen to Dick and ignore my posts. I should have known better than to post in a thread that involves physics. :redface:
This is more or less what I wrote down, but can I get away with acting like those dot products are multiplications?
To Micro: Don't worry :)
Not exactly. But if v is a vector then d(v.v)/dt=2*(dv/dt).v. You'll have to put in the dot products where I omitted them.
Ah, interesting, I can see where that would lead me. Thank you to the both of you :)
