Work is done by the force of gravity on the bike?
The discussion centers on calculating work done by gravity and by a force when pushing a bicycle and a stalled car. For the bicycle, the key formula involves the gravitational force component acting along the incline, which can be derived from the mass, incline angle, and distance. In the case of the car, the work done can be calculated by integrating the varying force over the displacement, represented graphically in a force-displacement diagram. Participants emphasize the importance of understanding the definition of work and the appropriate formulas to apply in each scenario. Clarification on these calculations is sought to resolve confusion.
geroallynne
I need help badly!
1. A bicycle rider pushes a bicycle that has a mass of 13 kg up a steep hill. The incline is 25* and the road is 275 m long. The rider pushes the bike parallel to the road with a force of 25N. How much work is done by the force of gravity on the bike?
2. Your car has stalled and you need to push it. Suppose for the first 15 m, your force decreased at a constant rate from 210-40.0N. How much work did oyu do on the car? Draw a force-displacement graph to represent the work done during this period.
Please help me. i am in need!
You need to know the definition of work. Can you state what it is as you understand it?
In these two questions, mainly the first i don't understand which formula to used. the ones that i have are W = Fd and W = fdcos* <-- theta..
and in the second question, i don't understand which formula to use either.
Thank you for your help
For the first one, which component of gravity does work along the path?
As for the second one, do you have any idea how you could calculate the work from the force-displacement diagram?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
