Work & Kinetic Energy Homework Solution
The discussion revolves around a physics problem involving a car's deceleration due to braking, specifically focusing on the work done by the braking force and the change in kinetic energy. The subject area includes concepts of work, kinetic energy, and the work-kinetic energy theorem.
  • Participants explore how to calculate the work done by the braking force and the change in kinetic energy, with some questioning the need for acceleration to find force. Others suggest using the initial and final kinetic energy values to address the second part of the problem.
Some participants have provided guidance on using the work-kinetic energy theorem and emphasized the importance of unit conversion from km/hr to m/sec. There is an ongoing exploration of the relationship between kinetic energy and work done, but no consensus has been reached on the specific calculations.
Participants note the potential confusion arising from unit conversions, particularly regarding speed in km/hr versus m/sec, which may affect the calculations of kinetic energy and work done.
sheri1987
With brakes fully applied, a 1670 kg car decelerates from a speed of 78.0 km/hr. What is the work done by the braking force in bringing the car to a stop?
What is the change in the kinetic energy of the car?
W=f*s, KE= .5(m)(v^2)
I am not sure if for the first answer how to start the problem, I have the mass, but I do not know the acceleration to solve for F...how can I go about solving this problem? Also for the second question I thought I would just have to use the equation for KE to solve, but it doesn't seem to be working...any suggestions?
Have you had the work-kinetic energy theorem yet? In any case, you can answer part 2 right off: what was the KE of the car at the start? what is the KE at the end?
The answers to both questions are the same. Energy is conserved, so the KE of the car is equal to the energy consumed by the braking force. If you are getting a wrong answer for the second part it's likely because you've overlooked that the speed is in km/hr. Not m/sec. Convert km/hr to m/sec.
I was resisting pointing this out. I wanted to find out if the point of the problem was to discover that this is the case. (If her course has covered the W-KE theorem, then the answer to one part would point to the answer for the other...)
for the second part of the problem do I use the equation KE =.5m(v^2) ...m= 1670, v = 78000 cause I have to convert it to m/hr...isn't the KE at the end 0, since the car stops? so wouldn't my answer be the final minus the inital?
Yes but v=78000 is completely meaningless. What units? The usual units of energy are joules. In that case you want the speed in m/sec. 78000 certainly isn't right. Hint, 1hr=3600sec.
Apologies. You did say it was m/hr. But that's not the number you want to plug into (1/2)*mv^2 to get joules.
  • · Replies 17 ·
  • · Replies 21 ·
  • · Replies 16 ·
