Calculating Work to Charge Parallel Conducting Plates
The discussion focuses on calculating the work required to charge a pair of parallel conducting plates, each measuring 30 cm x 30 cm and separated by 1.0 mm, with charges of +1.0 x 10-6 C and -1.0 x 10-6 C. The relevant equations include W = qV and Vplates = Qd/(ε0A). A key insight is that the voltage (V) changes as the plates are charged, necessitating the integration of V dq to accurately compute the work done. The initial assumption of the plates being neutral before charging is confirmed as correct.
  • Understanding of electrostatics and electric fields
  • Familiarity with the concept of capacitance
  • Knowledge of integration in calculus
  • Basic principles of electric potential and work
  • Study the derivation of the electric field for parallel plates
  • Learn about the integration of electric potential to calculate work
  • Explore the concept of capacitance and its relation to parallel plates
  • Review the principles of electrostatics in "Physics for Engineers and Scientists" by Ohanian and Markert
Students in physics, particularly those studying electrostatics, engineers working with capacitors, and anyone interested in the principles of electric fields and work calculations in electrical systems.
razidan
A pair of parallel conducting plates, each measuring 30 cm X 30 cm, are separated by a gap of 1.0 mm. How much work must you do against the electric forces to charge these plates with ##+1.0 \cdot 10^{-6} C ## and ##-1.0 \cdot 10^{-6} C##, respectively?
Physics for Engineers and Scientists (Third Edition), Ohanian and Markert, Vol 2. pp 823. Q.55
##W=qV##
##V_{plates}=\frac{Qd}{\varepsilon_0 A}##
So, plugging in the numbers gives a result twice the result in the book.
This leads me to think about a field of a single plate, ##E=\frac{Q}{ 2 \varepsilon_0 A}##, but I can't figure out why. and more in general, I'm not sure what the question is describing - are the plates initially neutral. and then they are charged?
Thanks,
R.
You didn't take into account the fact that V is changing while you charge up the plate. You must integrate ##V \:dq##
Oh boy...
Thanks.
  • · Replies 16 ·
  • · Replies 26 ·
