Would space stations of sci-fi fame actually work?
The discussion centers on the feasibility of spinning space stations creating artificial gravity through centrifugal force, as depicted in science fiction. Participants explore theoretical implications, practical challenges, and the mechanics involved in such designs.
  • Some participants argue that centrifugal force would not affect an astronaut unless they are mechanically fastened to the hub of the station.
  • Others propose that the analogy of water staying in a spinning bucket supports the idea that artificial gravity could work in a rotating space station.
  • A participant suggests that astronauts would need to move with the station to experience artificial gravity, and that typical designs would mitigate the effects of relative motion at walking speeds.
  • Concerns are raised about the size and complexity required for a rotating space station to be effective, as well as the current preference for microgravity in existing space stations.
  • Some participants discuss the necessity of a lateral force to initially get astronauts spinning with the station, after which centripetal force would maintain their circular motion.
  • A participant describes how air inside the station would move with it, affecting the motion of astronauts floating within.
  • Specific calculations are presented regarding the effects of rotational speed on perceived weight, with some participants noting the implications of riding at high speeds within the station.
  • There is a discussion about the effective gravitational force experienced by astronauts based on their motion relative to the station's rotation.
Participants express differing views on the mechanics and feasibility of artificial gravity in spinning space stations, with no consensus reached on the practicality or effectiveness of such designs.
Limitations include assumptions about the size and design of the space station, the effects of relative motion, and the complexity of constructing a rotating habitat. The discussion does not resolve these uncertainties.
F Mills
Would a spinning space station as depicted below that use centrifugal force to create artificial gravity actually work? I'm thinking that it would not, this is because the centrifugal force would not affect an astronaut inside unless he was actually fastened mechanically to the hub. The fact that it is only used in sci fi and not sci reality is another indication to me that it is not viable as an artificial gravity tool for space station inhabitants.
jedishrfu said:
Yes, it would work. Think of why water stays in a bucket as you spin it around.
Wikipedia as more on it:
https://en.wikipedia.org/wiki/Artificial_gravity
So i found an acceptable subject, good. I do think of it as water in a bucket, but the water in question is in zero (or micro) G. I see it as an astronaut just floating around while the space station walls are spinning around him. I just noticed you have a link, I have to post to be able to look at it. BRB
Still nothing to make astronaut adhere to surface. If you are buckeled into a seat on the inside of the hub, and forced to spin with the hull, I can see you experience G at that point. Otherwise unattached you would float off the surface as it spun.
In the spinning bucket it is not.
The astronaut would have to move around with the station, sure. What else do you expect? You don't want to shoot through the space station at high speed (as seen by the astronaut). If the astronaut moves relative to the station at high speeds, they will experience a higher or lower effective gravity, depending on the direction. Typical space station designs for artificial gravity are so large that this effect is small for walking speeds. And if you stand on the outer surface, you feel the artificial gravity downwards, you don't need any attachment.
Existing space stations don't rotate because (a) this requires some minimal size to be useful, and this size exceeds the current space stations, (b) it is much more complex to build such a space station and (c) most space station experiments want to use the microgravity environment. A small-scale test setup was planned for the ISS but got canceled due to budget constraints. Here is another proposal.
Thanks
Put simply, you would need a lateral force on the astronaut to get her spinning with the spaceship. But, once the spaceship and astronaut reach the required rotational speed, only a centripetal force is required to maintain the astronaut's circular motion. And, that force would feel much like gravity.
Consider the movie "2001: A Space Odyssey", which has a large rotating living-chamber inside a non-rotating spaceship. Astronauts enter the chamber from the rest of the ship via the axis and climb "down" a ladder towards the rim. Holding the rungs of the ladder provides the lateral force.
If there is air inside the space station then that air will move with the station. Otherwise it tends to swirl around light fixtures, doors and desks and gains speed in the process. If there are astronauts floating in the moving air then they tend to move with it. Otherwise it tends to muss their hair and speed them up in the process.
Like motes of sediment suspended in water in a test tube in a centrifuge, the astronauts then precipitate out onto the floor.
Consider a station with a 30 meter radius, and rotational speed at the rim of 10 meters per second. This would have an apparent surface acceleration of v^2/r = 10^2/30 or about 3 meters per second. Roughly Mars surface.
10 meters per second is roughly 22 mph.
Now put a bicycle track inside the station. If I ride at 22 mph with the direction of motion, I double my weight. If I ride against the rotation, I lesson my weight. Put a jump in place and do awesome tricks.
Acceleration scales with velocity squared. You experience 4g, which is quite uncomfortable.
Good point. But it would be 4 times the effective non moving (relative to the local chunk of station) force or about 1.3 G.
Ah, you took a Mars-like gravity as baseline, right.
1.3 g are fine.
  • · Replies 28 ·
  • · Replies 35 ·
  • · Replies 159 ·
16K
  • · Replies 19 ·
