Wow Anyone seen these pictures? Could they explain dark matter?
The discussion revolves around the potential implications of newly discovered structures in the Milky Way, specifically whether these structures could account for dark matter. Participants explore the relationship between these structures and the observed velocity curves of galaxies, addressing both theoretical and observational aspects.
  • Some participants question whether the newly discovered structures could account for dark matter, considering their density profile and energy content.
  • Others assert that the structures have no relation to dark matter or energy, emphasizing that they represent remnant radiation from known matter.
  • One participant suggests that the mass of the structures is insufficient to influence the galaxy's velocity curve, citing calculations that indicate a significant discrepancy between the mass of the structures and the expected dark matter mass.
  • Another participant discusses the nature of the radiation involved, arguing that it does not meet the criteria for dark matter and would require an unrealistically high density to account for it.
  • Some participants engage in a side discussion about the classification of galaxies, distinguishing between active and inactive galaxies and the criteria for such classifications.
  • There are claims that the Milky Way was an active galaxy until recently, prompting further questions about the definitions of active and inactive galaxies.
Participants express a range of views, with no consensus on the relationship between the newly discovered structures and dark matter. Some firmly reject the connection, while others explore the implications of the structures on dark matter theories.
Participants note that the discussion involves complex concepts related to dark matter, galaxy dynamics, and the nature of cosmic structures, with some claims requiring further clarification or mathematical backing.
komodekork
Astronomy news on Phys.org
What?! No. It has nothing to do with dark matter/energy. Did you even read the article?
Yes, I did read the article. I don't know much about dark matter, but as i understand it, the evidence for dark matter is that that the velocity curve of the galaxy falls off much slower than we expect with just the mass we see.
So this is a new, never before seen gigantic structure in the milky way, and my question is could the mass of this structure account for the flattening out of the velocity curve near the edges of the galaxy?
The article doesn't say anything eighter way, so could you expand on why this can not be? Is it as I said that the density profile is incompatable with two blobs on both sides, or is there something else I'm missing?
it is mostly radiation - highly energetic electrons - it wouldn't substantially alter the total projected mass for the milky way, just like a charged battery does not weight more than a depleted one - the difference is minuscule at most
this feature is common to all galaxies, just like quasars and pulsars have jets, in fact I am surprised it took NASA so long to discover it
Ah yes, the dark matter busters :D
Nevertheless I could never figure why those guys expect cosmic rays to interact with dark matter, in my book this is just wasting of resources in order to make a living on scientific funds...
I see. How dense would the radiation in the spheres need to be to account for the dark matter?
Ridiculously high? Because the radius of the spheres seems to be 12500 lightyears.
I am afraid answering that question requires stepping out of the scientific mainstream - and this forum is neither a place for that, nor a place that tolerates it. Anyway, I doubt those are actual spheres as in the artist impressions of nasa, they are jets which decay, something that is visible on the actual images, the spherical form is just an approximation of that observation, in reality those should resemble two opposite cones pointing the center of the galaxy, with the actual decaying ends forming a sort of a number 8 figure, only more elongated, like the sign for infinity
FlavioBER - I am sorry but you seem to have difficulties expressing yourself in English, maybe you should make yourself some more busy with learning the language and topic of this forum before posting - so that you can post adequately
The first problem is that the distributions are off: i.e. the dark matter 'halo' around the milky way is basically a sphere, with a radius a good deal larger than the size of the milky-way disk.
Remember that this radiation is just electrons and photons, so it doesn't match the 'cold' criteria of dark matter either.
But... the calculation would be very simple to do, to find out what density would be required to match the gravity of DM... and it would be extremely large. Significantly (between a factor of 100 and 1000) times more dense then baryonic matter in the milkyway
Cool pic and a huge discovery... we're all going to die!
No. Not even close.
1) there's been no new matter that has been discovered. You just see remnant radiation from matter that was already known to be there.
2) the matter comes from the intergalactic medium. If you run the numbers you'll find that the amount of matter that you end up when you add all of this together is 100 times less than dark matter.
3) it's in the wrong place. The flatten of rotation curves indicates that the matter is out near the edge of the galaxy. More matter in near the axis of rotation isn't going to help.
This *is* interesting because it suggests that the milky way was an active galaxy until rather recently.
It can't. If you dump more matter in the axis then it will cause all of the stars in the galaxy to rotate faster, but the reason we think that there is dark matter is that there is no drop off in the speed of the stars as you move away from the axis of a spiral galaxy.
Active as opposed to what?! Dormant?
Inactive.
zhermes said:
Inactive.
Please give me an example of an "inactive" galaxy.
The milky way. Or (off the top of my head), NGC 4321.
Only (something like) 10% of galaxies are active; I'm actually not sure about M31...
What I mean is how do I distinguish between an active and an inactive galaxy? Thank you.
An active galaxy, as can easily be found with a quick google search, is simply one which is much brighter than the standard galaxy. This is generally due to significant accretion at the central super-massive black-hole (e.g. AGN and blazars), but I believe there are instances where there is just an abnormally large rate of star formation taking place---not positive about that.
Thank you for steering me in the general direction. Is a Quasar an inactive galaxy?
No, quasars are active.
Eh, quasars are not galaxies but rather a sub-selection of AGN.
There are no inactive or dormnat galaxies.
Most galaxies are classified by type.
For example, A elliptical galaxy will be less active than a spiral one.
I agree in the technical sense this is true especially for people reading certain areas, however, most people, press and even books will refer to active and normal galaxies, the former having an active core and the others having a largely dormant core. Even MNRAS has a keyword for publication as Galaxies:Active.
Yes, that is surely true.
I was just trying to clear the air as in there are no dormant or inactive galaxies asa most readers have suggested.
  • · Replies 23 ·
  • · Replies 264 ·
24K
  • · Replies 66 ·
  • · Replies 37 ·
  • · Replies 20 ·
