Year 12 physics - thin films question
A soap film with a thickness of 100 nm and a refractive index of 1.33 will reflect light most strongly at a specific wavelength determined by constructive interference. The calculation involves adjusting the wavelength for the refractive index, considering whether there is a half-wavelength phase shift at the boundaries. The phase shift occurs when light reflects off a medium with a higher refractive index, leading to a 180-degree phase shift. The most reflected wavelength can be found using the formula that accounts for this phase shift and the film's thickness. Understanding the conditions for phase shifts is crucial for solving this type of thin film interference problem.
ash
I'm really stuck on this question:
A soap film is 100 nm thick. What wavelength of light will be most strongly reflected by this film; that is, what colour will it appear? (n soap = 1.33).
Any help you could provide would be greatly appreciated.
um.. would this be asking which would refract the most?
If so i would say red..
I know you need to adjust for the wavelength change due to n, but I can't remember if it's a 1/2 wave or a full wave coating. One is minimum reflection and the other maximum. Either
100nm x 1.33 x 2 or 100nm x 1.33
there is 1/2 wave inversion at the top surface, but no inversion at the bottom surface. The "most reflected" wavelength will experience constructive interference from both reflections. To do so, the second ray will travel a total distance through the film equal to 1/2 its wavelength in the film.
Can you take it from there?
just to refresh my memory, what determines the 1/2 wave inversion or not? Is it the sense of the the transition low index > high index vs. high > low, or something else?
low index > high index----reflect with 180 degree phase shift
high > low----reflect with no phase shift
the above two conditions + interference = answer of this problem
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
