Years to an engineering doctorate?
  • Thread starter Thread starter stann999
    Engineering Years
The discussion revolves around the duration required to obtain a doctorate degree in engineering, exploring various factors that influence this timeline, including coursework, research, and geographical differences in educational systems.
  • Exploratory, Technical explanation, Debate/contested
  • Some participants suggest that the time to earn a doctorate can vary significantly based on individual circumstances and institutional requirements.
  • One participant outlines a typical structure involving a year of courses, qualifying exams, and an indeterminate period for research and thesis writing, estimating a total of 4-10 years.
  • Another participant mentions that a PhD/DPhil typically requires 3-4 years of solid research, though this can extend longer.
  • Clarification is provided that the 3-4 years may start after either a master's or bachelor's degree, with specific funding constraints noted in the UK educational system.
  • A later reply indicates that the median time for completing a PhD may be closer to 5-6 years, suggesting that earlier estimates might have been overstated.
Participants express differing views on the typical duration for obtaining a doctorate, with no consensus on a definitive timeline. The discussion reflects a range of experiences and expectations based on geographical and institutional contexts.
Limitations include variations in educational structures across countries, differing definitions of what constitutes the completion of a doctorate, and the influence of funding on the duration of studies.
stann999
How many years does it take for one to acquire a doctorate degree in engineering?
Depends how long you spend to earn a doctorate!
Don't you take some high level courses then do research to make a big discovery and write a long paper on it?
A doctorate usually takes a year or so of courses, a few qualifying exams to prove you know your stuff, and an indeterminate number of years doing research and writing a small book about it called your thesis. The last part is done when it is done... but in total 4-10 years is probably a good estimate. Think 6-7 years on average.
A PhD / DPhil is 3-4(sometime longer) years of solid research.
Jim
Is that 3-4 years starting immediately after the master's degree or the bachelor's degree?
3 - 4 years from when you start your PhD some people have masters degrees, some go in straight from a bachelors. In the UK funding is usually only for 3 years, so if you go over that you have to fund yourself. The last year is usually used to write up your thesis.
Jim
I should have pointed out that PhD's vary by country, and I'm from the US. (Looking for some actual statistics, I might have overstated the situation a bit as well... it looks like the median time is more like 5-6 years, not 6-7.)
  • · Replies 18 ·
