You guys are gonna think im either stupid or crazy
  • Level: Undergrad
  • Thread starter Thread starter Arsonade
    Stupid
132 replies · 22K views
Ravenlock said:
Here is a actual quote from the US Patent Office regarding PPM's
"The views of the Patent Office are in accord with those scientists who have investigated the subject and are to the effect that such devices are physical impossibilities. The position of the Office can only be rebutted by a working model. ... The Office hesitates to accept fees from applicants who believe they have discovered Perpetual Motion, and deems it only fair to give such applicants a word of warning that fees cannot be recovered after the case has been considered by the Examiner"
I just thought that was interesting.
i believe that it says, Can only be rebutted by a working model, so ill build a working model, i already said that i plan to
Adam
russ_watters said:
To help you focus, what you are looking for are 1st law of thermo issues. Don't bother with friction, acceleration, and other losses, they are 2nd law issues. What prevents PPMs from creating useful work is the 1st law: Pout=Pin. The fact that your calculations come up with a non-zero net (>100% efficiency) means you are either neglecting a source of input or a source of internal consumption. A typical thermodynamic engine, for example, has an efficiency of around 35%, before you even consider losses. Electrical devices have a theoretical maximum efficiency of 100%.
I may have suggested this before, but a cheap way to fix this would be to hire an electrical engineer for an hour or two, with a written contract stating that he can't market your device. He'd likely find your error in 5 minutes and charge you $125 for the whole hour, but it'd save you a ton of time and money in the long run.
Now hold on, i never said that it worked at 100% efficiancy, i said that it was close, there is very little error available in the design and therefore works relitively efficiant. would that be more expensive that asking a physisist? and the electronics are not really the problem, the only elctic component is the generator.
Adam
ram1024 said:
or build the device yourself out of popsicle sticks and elmer's. nothing like first hand experience to remove all doubt...
lol well popsticle sticks would break and wouldn't give me nearly enough info, it wouldn't even be big enough for the magnets, no, i can't go that cheep.
Adam
use smaller magnets.
if it works on a small scale it'll work on a larger scale as well. nothing says your machine has to be house-sized ;D
u can't use magnets for a perpetual motion machine, magnet (permanent ones) wear off over time. Eletromagnets are a whole different story, and obviously can't be used for perpetual motion.
If it doesn't work at above 100% efficiency then it doesn't output more than is put in and it isn't a PMM. If its just a >1 C.O.P., (like a heat pump or a hydroelectric dam) then it isn't perpetual motion.
Ask whatever type of scientist/engineer that would understand the energy input/conversion. I was getting the picture that you have a fancy circuit of some sort that makes it appear you are getting more out than is being put in. That's why I suggested an EE.
May I ask what type of energy you have for an input?
Look theses magnets do wear out, but the energy used I am making them is easyly 1 billionth of the amount of energy produced in the length of time, the chances of me having to replace these magnets is slim, but in that event i am ready.
Adam
cant getem that small, it needs to be at least 2 feet high
Adam
russ_watters said:
If it doesn't work at above 100% efficiency then it doesn't output more than is put in and it isn't a PMM. If its just a >1 C.O.P., (like a heat pump or a hydroelectric dam) then it isn't perpetual motion. Ask whatever type of scientist/engineer that would understand the energy input/conversion. I was getting the picture that you have a fancy circuit of some sort that makes it appear you are getting more out than is being put in. That's why I suggested an EE.
really there is no kind of imput energy, that would kind of take away from the meaning of a closed system, magnettic? is that a good answer lol. Ill try the best i can with the nondisclosure form stuff, I am workin on it.\
Adam
The universe is in itself a perpetual motion machine, I'll bet with many more undiscovered ways of tapping into it's energy and manipulating it.
Frequent error is to have an error related to "magnet shielding" using diamagnetic material.
Normally, It is considered that diamagnetic "shields" (lowered) the magnetic field through it but really generates an opposite magnetic field that not only covered the space through it else modify the surronding space like a normal magnet.
Exactly, PMMs are all around us; the Water cycle, the CO2/ Oxygen cycle, the Nitrogen cycle, all cycles that should go on as long as the Earth exists.
I know about the magnet things, they really arent that important, it would just act in making the building of it easyer, also, some people i have talked to have givin me the idea that it would make my PMM run more efficiently, so ill use what i have. (whitch at the moment is nothing lol)
Adam
reply to vern on other post (its linked to here);
Vern said:
Ok; let me guess.
We take an electric motor, connect it to an electrical generator, connect the output of the generator to a step-up voltage transformer with a low voltage tap connected to the motor. The low voltage tap is designed to be the correct voltage for the motor. Then we take the high voltage output of the step-up transformer and power the world with it.
This one comes from folks who learn a little something about voltage transformers but don't understand how power works. It is very common; there's even a patent on it; it doesn't work, of course.
Vern
lol dude i didnt even know what a step-up voltage transformer was untuil you just mentioned it, why doesn't it work? can electricity not be divided that way or somthing, but anyway no that's not it, not close even, have u red the post?
Adam
