Z-transform and even/odd signals.
4 replies · 7K views
ace1719
"Let x[n] be a real-valued DT signal. Using the Pole-Zero plot of X(z), argue as to why:
a. |X(e^jω)| is even in ω.
b. ∠X(e^jω) is odd in ω.
Hint: if x[n] is real, what can we say about the poles and zeros of X(z)?
None.
I figure that X(z) will probably of the form, [itex]\frac{(e^jω-z1)(e^jω-z2)...}{(e^jω-p1)(e^jω-p2)...}[/itex], and I know even functions are defined by x(n)=x(-n) and odd functions by x(n)=-x(-n), but beyond that, not much.
If x(n) is real valued then:
x(n)=x*(n)
DTFT x(n) <-------> X(e^jw)
DTFT x*(n) <-------> X*(e^-jw)
X(e^jw)=Re{X(e^jw)} + jIm{X(e^jw)}
X*(e^-jw)=Re{X(e^-jw)} - jIm{X(e^-jw)}
since x(n)=x*(n), X(e^jw)=X*(e^-jw)
thus Re{X(e^jw)} + jIm{X(e^jw)}= Re{X(e^-jw)} - jIm{X(e^-jw)} so
|Re{X(e^jw)} + jIm{X(e^jw)}| = |Re{X(e^-jw)} - jIm{X(e^-jw)}|
Even symmetry.
sorry that looks sloppy...
You can use the same logic to show the phase is odd.Hint: real-valued signals result in complex-conjugate pairs.
I came up with an elegant solution to this problem, albeit it didn't use poles and zeros.
Re(x[n]) -> 0.5(X(z) + X*(z*))
Im(x[n]) -> -0.5j(X(z) - X*(z*))
Im(x[n])=0, therefore we can conclude that X(z) = X*(z*). (1)
I read in a book that, for real signals X(-z)=X*(z). (2)
|X(z)| = sqrt(X(z*)X*(z*)) (from eq. (1)). (3)
X*(z)=X(-z) and X(z)=X*(-z) (from eq. (2)). Substituting this into eq. (3) gives you:
|X(z)| = sqrt(X(z*)X*(z*)) = sqrt(X(-z*)X*(-z*)), which is the definition of an even function.
As for angle,
∠X(z) = arctan(Im(X(z)/Re(X(z)). Arctan is odd, therefore ∠X(z) is also odd.
If you see any mistakes, please respond.
That is all correct.
To use poles/zeros you just need to realize that real values create complex-conjugate pairs, so one real input will give you |a|e^jb and |-a|e^-jb making a z-plane plot look something like this:
. |Im
. | x
. | Re
. | x
So you can see that magnitude is the same (even) and the angle (pi/4 vs -pi/4 for example) is odd.
Sorry none of the spacing worked... I think you get the idea.
