Can Ampere's Law Confirm Zero Magnetic Field in Non-Enclosing Loops?
Ampere's Law states that the line integral of the magnetic field around a closed loop is proportional to the net current enclosed by that loop. In scenarios where an Amperian loop does not enclose any net current, the closed line integral of the magnetic field should indeed be zero, regardless of the loop's shape. This conclusion aligns with Maxwell's equations, which support the idea that magnetic fields are influenced by enclosed currents. The discussion emphasizes the importance of understanding the relationship between current and magnetic fields in complex configurations. Ultimately, applying these principles can help clarify the behavior of magnetic fields in non-enclosing loops.
jtabije
I had a thought that I hope you could give me feedback on:
Imagine a complex configuration that had a steady current, such that it's magnetic field was complex as well (I apologize for using 'complex' quite loosely here). If I were to apply Ampere's Law and form an Amperian loop that did not enclose any net current, would that imply that the closed line integral of the magnetic field along the loop is zero (regardless of the Amperian loop's shape)?
My brain is saying it's zero, but my mind is not yet convinced. Hopefully you can provide me a little more insight.
With thanks,
J.
Use Maxwell's equation (the integral form), and derive this, to convince your mind :).
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
