Solving for variables using 3 different equations (simultaneous equations)
To solve for variables A, T1, and T2 using the given simultaneous equations, start by isolating A in the first equation, resulting in A = (245 - T1) / 25. Next, express T2 in terms of A from the second equation, yielding T2 = 98 + 10A. Substitute these expressions for T1 and T2 into the third equation to solve for A. Once A is determined, use it to find the values of T1 and T2. Proper substitution and careful calculations are essential to avoid errors in the final results.
ReMa
Solve for A, T1 and T2.
Equa 1) T1 + 25.0a = 245
Equa 2) T2 − 10.0a = 98.0
Equa 3) T1 − T2 − 80.0a = 78.4
As above.
I isolated a in the first equation:
a = (245-T1)/25
and T2 in the second equation:
T2 = 98 + 10(245-T1)/25
And when subbing these values in I end up getting an answer WAY off for T1. Any help would be highly appreciated as I feel like I'm just doing improper calculations with my fractions...
Solve for T1 in equation 1 and for T2 in equation 2. Both T1 and T2 will be in terms of a. Substitute for T1 and T2 in equation 3, and solve for a. After you get a, you can get T1 and T2.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
