Finding Ricci Scalar Constant Nonzero Line Elements
alejandrito29
i need examplees where the ricci scalar is constant but nonzero . Particulary i search examples of line element.
Pd: this is not a homework,
I'm not sure if you are referring to spaces or spacetimes. If spaces, then maximally symmetric spaces have the property that the Ricci scalar is constant everywhere. In 3 dimensions these are the 3-sphere and the 3-hyperboloid (and Euclidean space, but there R=0). If you are referring to spacetimes, then the Ricci scalar is proportional to the trace of the stress tensor (T), so you need to find some spacetime with constant T everywhere. I can't think of any examples of the top of my head.
Minowski space should have a constant Ricci scalar, right? But it is zero, from what I gather.
Yup.
de Sitter spacetime and anti-de Sitter spacetime.
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
