What Defines Organic Substances in Chemistry?
  • Thread starter Thread starter no idea
    Organic
Organic substances are primarily defined as compounds containing covalent bonds, typically characterized by low melting points and limited solubility in water. They are not stable in hot concentrated sulfuric acid, which is often used to identify organic matter through oxidation, resulting in coal-like carbon particles. The discussion clarifies that organic compounds generally exclude carbon oxides, carbonates, and cyanides, with a focus on carbon compounds that have a formal valence of less than 4. This includes hydrocarbons like methane and its homologs, as well as carboxylic acids. Overall, the conversation aims to provide a foundational understanding of what constitutes organic substances.
no idea
what is organic substances?
Chemistry news on Phys.org
Hello, I think you need very elementary knowledge of organic substances.
Well, if a substance contains covalent bonds rather than ionic, not having a high melting point, not very soluble in water, we may briefly consider it to be a potential organic substance. Organic compounds are not stable to hot concentrated sulfuric acid; and this test is frequently done to search any organic matter in a given substance. If there is some, then some coal-like carbon particles occur due to sulfuric acid's oxidation.
I think that is enough for a person wondering what organic substances are. But we are eager to help you, if you have further questions.
regards, chem_tr
Carbon compounds not including oxides, cyanides, or carbonates.
but isn't carbon dioxide has a low melting point?
As Shawn says, excluding oxides.
Yes, I agree with Shawn and Janitor and add that any compound containing carbon less than 4+ formal valence (indicator of CO2) might be organic. C4- is characteristic of methane, and C3- is its homolog alkanes; C2- is of ethylene and other terminal alkenes, and so on. When we come to C3+, it is seen with all of carboxylic acids. But the statement "any carbon compound excluding carbonates, cyanides and dioxide" is simpler. Note that nitrile and cyanide are similar in structure, with the difference being covalent and ionic, respectively.
I hope you've gained an idea about organic substances.
Regards, chem_tr
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
