Combining Identical LEDs: Power Increase or Not?
Combining two identical LEDs, each with a power output of 300mW, theoretically results in a total output of 600mW, provided they are connected under the same conditions. However, the effective increase in light output may be limited by the principles of étendue, which dictate that light sources cannot be concentrated beyond certain geometric constraints. When two LEDs are placed together, their light can add up, but the maximum intensity on a surface remains unchanged. This phenomenon is due to the incoherent nature of the light emitted from the LEDs, allowing for simple addition of power without enhancing concentration. Understanding these limitations is crucial for optimizing LED configurations in practical applications.
Learned
Hello,
I was wondering if anyone know the physical explanation about the following:
What happens if I combine two Identical LEDs with the exact same spectral profile (eg 350-450nm with 400nm center wavelength and peak).
Assuming the total power of each LED in watts is 300mW. Will the combination of the identical LEDs make for 600mW?
If so, why?
If not, Why?
Thanks in advance for your help.
As long as the power supply situation for the LEDs does not change (and therefore both LEDs have the same conditions as the single LED before), you can just add the power.
Thanks for the reply. I have heard from people that they are not suppose to add up- although I got no reasonable explanation for why not.
Since you say it should add up. Could you please breifly explain why?
Thanks in advance
How you add light sources is limited by ETENDUE.
Look it up on Google..Also..Roland Winston..he's the father of this stuff..used to be at
U.of Chicago now at U. of Merced. Also, Juan Minano, Pablo Benitez, Julio Chavez in Spain have done a lot of work in this. There's a couple of books on Amazon.
Basically, area*sin(emission angle half angle) is a constant..in 2d..also called Lagrange Invariant ..this is covered well in books on Non-Imaging Optics.. also look for limits to concentration
so if you have an led without a lens emitting into 180 degrees then you can't concentrate that further. If you put another one next to it the far fields add up , but no concentration improvement possible.
Typical technology for moving flux from one place to another are CEC's (Compound Elliptical Concentrators) or CPC's (Compound Parabolic Concentrators).
I am available for consulting, btw.
Assuming that they are not arranged in a way that the light from A hits B in a significant amount or B blocks A it in other ways (and vice versa): You have a simple incoherent addition of two light sources.
The maximal intensity on a (small) surface cannot be increased, but I don't expect that you care about that, as you mentioned the total power.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
I passed a motorcycle on the highway going the opposite direction. I know I was doing 125/km/h. I estimated that the frequency of his motor dropped by an entire octave, so that's a doubling of the wavelength. My intuition is telling me that's extremely unlikely. I can't actually calculate how fast he was going with just that information, can I? It seems to me, I have to know the absolute frequency of one of those tones, either shifted up or down or unshifted, yes? I tried to mimic the...
