Questions about Waves - Answers and Explanations
  • Thread starter Thread starter Tosh5457
    Waves
The discussion addresses several key concepts in wave theory, particularly the interpretation of the complex wave function u(x,t) and its real and imaginary parts, which correspond to different frequency components. It clarifies that the phase velocity of a wave can equal the wavefront velocity under specific conditions, such as non-dispersive media. The wavefront can be identified through the gradient of the wave function. Negative values for temporal and spatial frequencies indicate wave components traveling in reverse directions and can be visualized in terms of frequency and wavelength. Lastly, the Fourier series or transform provides an exact solution to the wave equation, with validity determined by Dirichlet conditions.
Tosh5457
Hi, I got a couple of questions which I couldn't find the answer for when I studied. I hope some of you can answer them or provide links explaining :smile::
1) When a wave is written in the complex form, such as
u(x,t)=A(x,t)e^{i(ωt-kx)}
what's the physical meaning of u(x,t)? I imagine u doesn't have a physical meaning, but what about its real and imaginary parts (Re(u) and Im(u))?
2) Is there a difference between wave packet, gaussian packet and a wave?
3) In a propagation wave, is the phase velocity the velocity of the wavefront?
4) How do you know what's the wavefront from the wave function?
5) Do ω (temporal frequency) < 0 and k (spatial frequency) < 0 have a physical meaning? Why are negative values considered?
6) Why is the intensity of a wave u, ||u||^2? The only argument I saw was one of dimensional analysis...
7) The solution of the wave's equation in one dimension can be approximated by: u(x,t)=A(x,t)e^{i(ωt-kx)}
The general solution is a Fourier series/Fourier transform if I'm not mistaken. When is this approximation valid?
8) How is the spatial frequency vector k related to the Poyinting vector?
9) How to show that the Poyinting vector points to the direction of the wave's propagation? (just the basic idea behind that proof would be appreciated).
Thanks.
To answer the first two: because of Euler's identity, u(x,t) has the same physics meaning as whatever the wave equation has in the none-imaginary representation-- or at least the real part does!
And a wave packet is essentially an "envelope" in which a little bit of a wave that increases then decreases- and envelope that has within it a packet of the wave! The wave itself is the inside thing.
Thanks for your answer. Nobody else can help? :(
The real part contains all of the frequency components which are non-zero when an inner product is taken against the cosine function. The imaginary part contains all of the frequency components which are non-zero when an inner product is taken against the sine function. (The real and imaginary parts are orthogonal to each other)
Sometimes. For that to be the case the phase velocity vector must be oriented in the same direction as the wave propagation vector (group velocity vector) and the medium cannot be dispersive. There are other stipulations.
The wavefront should be the gradient of the wave function solution I believe.
They might be more visualizable as having physical meaning if you convert them to frequency and wavelength. (ω is angular frequency). Negative values mean the wave component travels in the reverse direction.
I believe the FS or FT is exact, not an approximation. The Dirichlet conditions specify when a FS is not valid.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
I passed a motorcycle on the highway going the opposite direction. I know I was doing 125/km/h. I estimated that the frequency of his motor dropped by an entire octave, so that's a doubling of the wavelength. My intuition is telling me that's extremely unlikely. I can't actually calculate how fast he was going with just that information, can I? It seems to me, I have to know the absolute frequency of one of those tones, either shifted up or down or unshifted, yes? I tried to mimic the...
