E-Field Attenuation: Causes & Effects
Electric fields do attenuate in space, following the inverse square law, where the strength of the field decreases as the distance from the source increases. This attenuation occurs because the field lines become less dense as one moves away from the source. Similarly, gravitational fields also experience attenuation in space, as the gravitational pull diminishes with distance from a planet. The underlying cause of this attenuation is the geometric spreading of the field lines. Overall, both electric and gravitational fields weaken with increasing distance from their sources.
Apteronotus
Do electric fields attenuate in space?
If so what causes the attenuation?
I am not sure what you are looking for. In general fields spread out and therefore attenuate, following an inverse square law.
When I move away from a planet farther into space, its gravitational pull on me decreases right?
Would you say that the gravitational field is attenuated in space?
What would be causing this attenation?
Inverse square law.
We can visualize the strength of a field by thinking of field lines. Near the source of the field the field lines are all very dense. As the distance from the object increases the density of the field lines falls off in accordance with the inverse square law. http://en.wikipedia.org/wiki/Inverse-square_law
Thank you for your responses.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
I passed a motorcycle on the highway going the opposite direction. I know I was doing 125/km/h. I estimated that the frequency of his motor dropped by an entire octave, so that's a doubling of the wavelength. My intuition is telling me that's extremely unlikely. I can't actually calculate how fast he was going with just that information, can I? It seems to me, I have to know the absolute frequency of one of those tones, either shifted up or down or unshifted, yes? I tried to mimic the...
