Value of the constant in 'variation of refractive index'
Donchay
In optics, given the below formula
nλ= A + B/λ2 + C/λ4 +...
where A, B and C are constants.
From the above relationship we can deduce that as the wavelength λ increases, the variation of refractive index nλ decreases.
How do we measure the constant value of A,B and C at the first place?
You measure the refractive index at several wavelengths and then you fit the formula to the values obtained.
Thank You DrDu.
While the above formula is for Optical Dispersion, then is it the same dispersion for the Abbe Number:
Vd=(nD-1)/nF-nC
where nF-nC is the dispersion according to this link http://glassproperties.com/abbe_number/
but somehow on other link I read that nF-nC is called Principal Dispersion. I try to search on more about Principal Dispersion but there is almost none explanation about it.
n_F is the index of refraction for blue light while n_C is for red light (see the table with the line frequencies).
One assumes that for glass the dispersion is approximately linear over the optical frequency range.
I understand about the line frequencies. Just that is it n(lambda)=n_F - n_C ?
I would try something like ## n(\lambda)=n_C+(n_F-n_C)\frac{1/\lambda_C^2-1/\lambda^2}{1/\lambda_C^2-1/\lambda_F^2} ##.
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
