| New Reply |
Area perpendicular to a magnetic field from Faradays Law |
Share Thread | Thread Tools |
| Dec25-12, 06:59 PM | #1 |
Hello Everyone,
I have a question concerning the "Area perpendicular to the magnetic field". If the field was produced by a permanent magnet, would the "Area perpendicular to the magnetic field" be the same size as the Area of the permanent magnet? |
| Dec25-12, 07:22 PM | #2 |
Mentor
| Dec25-12, 07:55 PM | #3 |
When calculating voltage for an axial flux generator with a permanent magnet rotor,
would the "Area perpendicular to the magnetic field" be the Area that the wire in the stator occupies, or would the "Area perpendicular to the magnetic field" be the same size as the Area of the permanent magnet? I believe the " Area perpendicular to the magnetic field" is is Area of the permanent magnet that the field is coming from and not the Area of the stator that the wire occupies but i need someone that knows more about Faradays Law to tell me if im right or not? |
| Dec26-12, 11:49 AM | #4 |
| Dec26-12, 12:09 PM | #5 |
Nice job Don !!! Great link, and scholarly....
The voltage is determined by the magnetic flux enclosed by your turns.... Well,,, Actually by rate of change of that flux.... Probably there's several different ways to calculate that. @ original poster: Brush up on your magnetic units. One weber per second will cause one volt in one turn whatever its area. You'll have to adapt that to whatever geometry and units you are given. old jim |
| New Reply |
| Thread Tools | |
Similar Threads for: Area perpendicular to a magnetic field from Faradays Law
| Thread | Forum | Replies | ||
| Why do magnetic fields only apply force to charges moving perpendicular to the field? | Introductory Physics Homework | 1 | ||
| Magnetic field created in a perpendicular point | Introductory Physics Homework | 0 | ||
| why is electromagnetic force perpendicular to magnetic field? | Classical Physics | 0 | ||
| Magnetism - Circular Loop in a Perpendicular Magnetic Field | Introductory Physics Homework | 2 | ||
| Why the charged particles flow perpendicular to the magnetic field?? | Advanced Physics Homework | 1 | ||
